Aux-In question!
simon2015uk
In: Sumatra
Aux-In question!
Post by simon2015uk »
Hey guys, I have an Aux-In port on my arm-rest, and I have plugged my phone in via it, but nothing happens if I play music...it just plays on my phone as normal?
Am I meant to enable something?? Can I even play music through it?
Cheers! :D
C00PS
Options: Red LED foot well lights.
Red LED reading lights.
LED number plate lights.
Yeti tail pipes.
Metal pedals.
GT engraved foot rest pedal.
GT steering wheel Emblem.
Re: Aux-In question!
Post by C00PS »
simon2015uk wrote:Hey guys, I have an Aux-In port on my arm-rest, and I have plugged my phone in via it, but nothing happens if I play music...it just plays on my phone as normal?
Cheers! :D
Have you tried pulling the Aux end that is plugged into your phone out a bit? Sometimes they only work when not all the way in.
Could be a faulty Aux cable. Have you tried it on another device?
Could use Bluetooth if you have it in your car?
Sent from my SM-G925F using Tapatalk
I'm pretty sure there is a setting on the headunit to enable / disable aux in. There is also a setting for gain / sensitivity for the input.
sciroccorich
Options: Black Leather, Parking sensors and RNS Satnav/DVD player
Post by sciroccorich »
Sorry if this is a daft answer but after you have connected your phone, have you pressed the media button on your head unit and then selected the AUX tab at the top of the screen.
This is normally what you have to do to make it work, the same way that you would select CD, SD Card or internal hard drive (if it has one).
TheHungryHipo
Post by TheHungryHipo »
Have you tried connecting another device? I might be wrong here but I'm almost certain that whether or not the AUX is turned on at the headunit, music shouldn't be playing through your phone when there's an AUX cable plugged into it. Also is it definitely an AUX input, or is it a Media input?
Huttchy
In: Indium Grey
Options: GT Spec:
- 18" Alloys
- Fog lights
- Multifunctional steering wheel, ETC
- Stage 1 REVO Remap
- Gauge Sweep
- De-badged
- De-wipered
- Powerflow cat-back
- Full white LED interior lights
- Red Footwell LED's
- Concept RS Front Splitter
- R Rear Lights
Post by Huttchy »
hello, I have the same problem but its fine after iv removed any USB/SD cards. it only recognises one device for mine anyway
hope this helps :)
Aron
simon2015uk
In: Sumatra
It is enabled on the dash screen (has a tick), it is a new AUX cable I just bought, does it only detect certain devices? I only have a HTC M9 to use.
simon2015uk wrote:It is enabled on the dash screen (has a tick), it is a new AUX cable I just bought, does it only detect certain devices? I only have a HTC M9 to use.
It's a simple 3.5mm stereo jack so there is no "intelligence" to it for it to be able to only select certain devices. When you plug the cable into the phone, the phone should stop playing through the phone speaker irrespective if the other end of the cable is plugged in or not. Do headphones work OK on the phone?
simon2015uk
In: Sumatra
Headphones work fine, I use them daily
I plug the cable from the AUX port into my phone and literally nothing registers. I thought maybe a duff cable, but its brand new
