Since taking delivery of the Rocco on 1st April, about 5 maybe 6 times now (although totally randomly), when the mirrors have been folded and I turn the mirror switch to any position other than "folded", 9 times out of 10 they unfold properly, however as stated a number of times nothing happens.
The other day, I moved the mirror switch about 6 times and nothing. Even turned the ignition on and off a couple of times - nothing. Eventually on the 6 or 7th time, they worked.
Like I said it's totally random and has only happed 5 or 6 times since owning the car, but I'm a bit worried they might stick in the closed position ? I use the function a lot as our car park spaces at work are quite narrow. Is this a dealer check ?
Also, whilst I've got your attention (please
Thanks again.
