Panel filter in an R
Ladies/Gents,
I have just sold my GT TDi and purchased an R . . . which I am loving!
I've purchased an aftermarket panel filter . . . . but I have no idea how to take the engine cover off?!?!
Has anyone got any tutorials or guidance because I am puzzled!
Thanks in advance,
Martin
Thanks in advance,
Martin
Re: Panel filter in an R
Is it not in the owners manual??
Heres a guide the Mk5 boys used
http://www.swankmonkey.com/vw/jetta/200 ... ine_cover/" onclick="window.open(this.href);return false;
I haven't noticed it in there when I read through, but will have another check when I get to my car!
Here's the EVOMS guide.....
http://www.evoms.com/WebSiteUsers/evoad ... ctions.pdf" onclick="window.open(this.href);return false;
Thanks Chungster,
I will take have a go later on tonight. My engine covers looks a little different to this but its a good place to start.
the difference is merely branding, one tip is to warm the car slightly (only a few mins) to warm up the plastic, easy to break the lugs and these are ludicrous money from VWhorsleym wrote:Thanks Chungster,
This is how my engine bay looks.horsleym wrote:Thanks Chungster,
http://www.sciroccocentral.co.uk/forum/ ... =33&t=7078" onclick="window.open(this.href);return false;
But you can see the front 2 lugs are in identical positions and even tho my pics don't show the back 2 I'm sure it's there as the engine blocks are the same type.
But I will say Forge removed mine for me and I've never had the pleasure to remove one myself
if its not got the 2 lugs at the back like the instructions chungster has kindly provided it may have 1 at the rear that the lug slides forwards to release from ( http://www.sciroccocentral.co.uk/forum/ ... ard#p73448" onclick="window.open(this.href);return false; )Chungster wrote:But you can see the front 2 lugs are in identical positions and even tho my pics don't show the back 2 I'm sure it's there as the engine blocks are the same type.
Different engine block trixy
I didn't look at my cover before putting it in the shed but I reckon it's identical to the Mk5 so those 2 links I provided should be correct.
![Wink ;)](./images/smilies/wink.gif)
just covering all possible configurations, as wigit says the lugs are expensive for what they are so if it doesn't release 1 way here is another to try just in case, rather than over forcing one and breaking it ![Smile :)](./images/smilies/smile.gif)
Womens way of thinking....... ![Wink ;)](./images/smilies/wink.gif)
Here you go this is what i used for another TFSI engine with the same type of cover. The filter is then removed by extracting numerous cross head screws.
This looks like the one!!!cajpaj wrote:Here you go this is what i used for another TFSI engine with the same type of cover. The filter is then removed by extracting numerous cross head screws.
Thanks to all that have replied, hopefully i'll get it sorted this week . . . :o)
Best thing to do is just forget fitting the panel filter.
Its one of the biggest myths around that you get any benefit from a panel filter.
Just replace the paper filter more often if you're that worried about air flow.![Wink ;)](./images/smilies/wink.gif)
I could swear I can hear more induction noise after fitting one than b4, my advice is go to awesome GTI and buy one, then talk Al into fitting it for youAndy-GTI wrote:Best thing to do is just forget fitting the panel filter.
![:P :P](./images/smilies/tongue.gif)
But yes I didnt do it thinking I was going to gain any HP
Solar Orange TT RS
It's all in the mind innit...if you've paid for it...you just "know" there must be an increase in noise and more bhp etc etc...
but I'm with Andy-GTI regarding Panel Filters. Never rated them...never will. The OE cotton filter does an ok job with the OE enclosed housing.
I thought that there cant be much of a difference. Had one fitted anyway just to see. Slight bit more noise if you give it some in a multi-story or tunnel I think. And for some reason it feels like it feels a bit more eager with revs - obviously its minimal though. Someone may / may not be able to notice it, and as mentioned if you buy one with expectations it could well be in your head.Chungster wrote:It's all in the mind innit...if you've paid for it...you just "know" there must be an increase in noise and more bhp etc etc...
