First year time and distance service price...
- scirocco
Guys how much have you being paying for your first year time and distance services?
Re: First year time and distance service price...
I'm paying £15/mth as part of the three year service, maintenance and tire package (1 yr servicing).
Darkness - £15 for all three? I was quoted £15 for service and maintenance (i.e. anything not under warranty inc wear and tear) but was told that as tyres are so expensinve this adds £30 per month as, over the 3 years, you'll need a new set fa'sure. Are you getting a free new set for that £15/ month?!The Darkness wrote:I'm paying £15/mth as part of the three year service, maintenance and tire package (1 yr servicing).
17th October - Now it's finally mine
£0 - got three years / 30,000 miles service thrown inscirocco wrote:Guys how much have you being paying for your first year time and distance services?
But going from what we paid for the Passat, Year 1 (2008) was under £100, Year 2 (earlier this year) was nearer £250 and I wouldn't have thought the type of service would be too different in the work carried out - probably just an oil change for the 1st service.
Y for all three. I'm assuming its because I stated I'd only be doing 5000 miles/annum, maybe they think I wont be needing a new set in that timeframe....regandjuk wrote:Darkness - £15 for all three? I was quoted £15 for service and maintenance (i.e. anything not under warranty inc wear and tear) but was told that as tyres are so expensinve this adds £30 per month as, over the 3 years, you'll need a new set fa'sure. Are you getting a free new set for that £15/ month?!The Darkness wrote:I'm paying £15/mth as part of the three year service, maintenance and tire package (1 yr servicing).
I had my first service done at 17.5k and 10 months old. Price all in was £147.
Not bad at all.
Not bad at all.
- scirocco
Not bad at all for a longlife service! Im looking at £90-£120 for a time and distance service....
Sounds about right. TBH i think 17.5 miles is a bit long for a service. I would rather it be every 10k.
Ah, I see......yes, they reckoned about 17k plus for tyres (which seemed optimistic to me) but as I'm 12k a year i'd definitely need new ones. Cheers for the info!!The Darkness wrote:Y for all three. I'm assuming its because I stated I'd only be doing 5000 miles/annum, maybe they think I wont be needing a new set in that timeframe....regandjuk wrote:Darkness - £15 for all three? I was quoted £15 for service and maintenance (i.e. anything not under warranty inc wear and tear) but was told that as tyres are so expensinve this adds £30 per month as, over the 3 years, you'll need a new set fa'sure. Are you getting a free new set for that £15/ month?!The Darkness wrote:I'm paying £15/mth as part of the three year service, maintenance and tire package (1 yr servicing).
I've done 20.5k on my P zero's, they are starting to looking a bit border line now though.regandjuk wrote: Ah, I see......yes, they reckoned about 17k plus for tyres (which seemed optimistic to me) but as I'm 12k a year i'd definitely need new ones. Cheers for the info!!
20k out a set of fronts you must be driving it like a granny
- Nobby
What if your granny is Mary O'Andretti ?
- scirocco
Thats impressive milage out of a set of front tyres. I hope mine last as long....
Got 17k out of mine so far but they are going to require replacing in the next month i think. Motorway miles
- jonallen628
I have just been quoted £149 for time and distance service which seems a little steep.scirocco wrote:Not bad at all for a longlife service! Im looking at £90-£120 for a time and distance service....
Black is the new Black....
- silver130
I had mine serviced yesterday at Listers Nuneaton. £95 all in. Fixed price.
Also. They have completed a recall from Volkswagen.They have changed the bolts on the tailgate struts that were rusting on a lot of cars with modified bolts (which look exactly the same to me)
It's a shame they haven't recalled them to turn the chuffing daytime running lights off though.
They also looked at the jittery windows and jittery wiper arms that had materialised some time ago but i was'nt concerned enough to take it back for.
It's back in next week to fit a new ignition switch (quite common with Scirocco's) to cure the windows and fitting modified wiper arms for the windows. (Again not unknown to VW)
They have also said that they will check with VW in Germany about the DRL's as they seem to think there has been a fix issued to resolve this with early cars. (won't hold my breath on that one though)
All in all. Very pleased with the service i received.
IF IT'S NOT BROKEN
I'VE NOT TOUCHED IT YET !!
- scirocco
Did your dealer know about the modified wiper arm. When I was booking my car in for the service I was chatting to the service manager and he knew nothing about the wiper smear issue on the Scirocco, but would look into it. He did say they modify the tension on wiper arms all the time across the vw range to resolve wiper smears...
Same here.haws wrote:Motorway miles
Best price ive been quoted is £119 for P zeros.
- silver130
Bizarre as it sounds. Mine does not have the smear which seems to affect a lot of Scirocco's. Mine chatter away to themselves when they are in the park position when the car is moving. Happens in all weathers as well.scirocco wrote:Did your dealer know about the modified wiper arm. When I was booking my car in for the service I was chatting to the service manager and he knew nothing about the wiper smear issue on the Scirocco, but would look into it. He did say they modify the tension on wiper arms all the time across the vw range to resolve wiper smears...
Just my luck that they will start to smear when the new wiper arms are fitted.
IF IT'S NOT BROKEN
Dont want to disapoint but i dont think the arm will help. Mine went back countless times for the smear and the only thing that cured it was a new windscreen.
Dont ask me how or why you could have a faulty windscreen, all i know is i no longer have a smear.
