I am after a roof rack and have done some research and browsed a few old threads on here and found out it's quite tricky to get a decent one - also if you have one for sale I would love to hear from you
- Genuine VW option - If someone has one for sale I would be interested!
- Modula Aluminium rack - Any comments on this? Available for around £130 on ebay
- PreAlpina LP49 - Any comments on this? Available for around £130 on ebay
Other than that, I have seen you can get second hand Thule 754 feet and then Thule Aero bars of your choice for a good price second hand. Thule used to produce the mounting hardware for a Scirocco under part number 1631 which is no longer available, but looking into the documentation you can still buy the front Scirocco mounts (PN 1139 - source https://www.roofracks.co.uk/pdf/1631.pdf" onclick="window.open(this.href);return false;) which are the same front mounts from a Ford Cougar Coupe.... Only problem now, what do you use for the rear mounting. The part 1140 in the above manual is no longer avaialble.
Thanks all!
