Blue Scirocco 2.0 TSi
jclayton14
Post by jclayton14 »
Thought I'd show the progress on my scirocco so far. Not done much as yet but plenty planned.
Done the gloss black badges first of all then had the wheels powder coated in satin black and painted the calipers in yellow.
Got some vinyl on order to wrap the trim parts on the dash and getting the wing mirror caps painted gloss black too soon.
Plenty more to come. Watch this space [emoji106]ImageImageImageImageImageImageImage
Sent from my Pixel 2 XL using Tapatalk
jclayton14
Re: Blue Scirocco 2.0 TSi
Now got the dash and door trim parts wrapped in Matt black. Left the centre piece around the headunit as I think it breaks the dash up nicely. Very pleased with the end result [emoji106]ImageImageImageImage
Tom20
I drive a: 1.4 TSI 122/125
In: Dark Oak
Options: 18 inch aluminum rims, Dynaudio Sound System, tinted windows,...
Post by Tom20 »
Hi jclayton14
This is a very nice scirocco!
Especially in rising blue.
also certainly with the black rims and the yellow calipers.
Did you paint them by hand?
jclayton14
Tom20 wrote:Hi jclayton14
Callipers were done by hand using hammerite engine paint. Took advantage of the car being on axel stands while the wheels were powder coated in satin black [emoji106]
Tom20
In: Dark Oak
Post by Tom20 »
These are now really beautiful.
Especially behind that satin black!
It gives something extra :yes: :clap:
Pads
Post by Pads »
How hard were the trim pieces to wrap and what did you wrap them with?
Cheers, nice colour combo btw :yes:
jclayton14
Pads wrote:How hard were the trim pieces to wrap and what did you wrap them with?
The dash trim pieces were quite easy to wrap. Just used a Matt black vinyl from eBay and a heat gun or hair dryer to shrink wrap them. The door handle inserts were sprayed Matt black as they are a difficult shape to wrap for a novice.
Pads
Post by Pads »
Thanks dude!
Bauerutc
Post by Bauerutc »
Looks nice and you have done a few mods which i will be looking at doing when i buy one!
jclayton14
Got a ticking noise coming from the engine when idling. Been told it was the cat burning extra fuel it's drawing from a previous remap.
Took it to dynotune my local remap specialist and they did a decat for me and also remapped to try and sort it but it's still there. Think it's now a tensioner.
Also have the black wing mirror caps on, found them on eBay brand new for £16.99 an absolute bargain for a set!ImageImage
Pads
Post by Pads »
What are you doing about the tensioner? Im considering getting mine done as a precaution
Zanic L3
Post by Zanic L3 »
Pads wrote:What are you doing about the tensioner? Im considering getting mine done as a precaution
I've asked someone who did it before and he told me that VW quoted him €3200. But that was also with a new chain, tensioner and seals
Argonaut
Options: R-line exterior, "Edition" version which means black roof with panoramic window and special sport seats.
Post by Argonaut »
Nice car Tom! I hope you get it lowered soon :D
jclayton14
Turns out the ticking noise while idling was chain chatter caused by a faulty tensioner so had this replaced and now sounds perfect again and can get back to concentrating on some more mods. Only cost £140 to replace too.
Zanic L3
Post by Zanic L3 »
jclayton14 wrote:Turns out the ticking noise while idling was chain chatter caused by a faulty tensioner so had this replaced and now sounds perfect again and can get back to concentrating on some more mods. Only cost £140 to replace too.
140 only for the tensioner?
Roy_01
In: Sumatra
Post by Roy_01 »
You are very lucky, were you driving with the old model tensioner?
jclayton14
Yeah I was surprised too but it's only the tensioner. No new chain or anything life that.
jclayton14
Roy_01 wrote:You are very lucky, were you driving with the old model tensioner?
Think so, it's an early model.
NightSky
In: Opal Silver
Post by NightSky »
Hi guys,
I just bought scirocco 2.0tsi 107k miles and I want to change chain tensioner on it as there are no evidence that it was changed in the past.
I`ve called to TPS and they`ve told me that there are two different tensioners going on my scirocco? Do anyone know which one is the 'Good' one? When changing chain tensioner do you need to spill out oil out of the car, because service just been done on it?
Thank you
JeffW
Options: 260bhp Stage 1 remap, EBC brake upgrade
H&R ARBs, WALK, KW lowering springs,
K&N intake, sports cat down pipe
Post by JeffW »
NightSky wrote:Hi guys,
Thank you
The part number for the tensioner (when I did it recently) was 06K109467K. Double check it on http://www.oemepc.com" onclick="window.open(this.href);return false;.
If it helps: Link to the diy guide I found on a GTI MK5 forum. " onclick="window.open(this.href);return false;
This guide doesn't say you should drain some of the oil first, you should, because the oil level is above the bottom of the cover (half a litre should do). I used a trolley jack under the sump rather than an engine bridge. It also talks about a noise pipe, which we don't have on RHD cars.
