SCIROCCO 2011 Facelift done
Argonaut
Options: R-line exterior, "Edition" version which means black roof with panoramic window and special sport seats.
Post by Argonaut »
Hello!
My name is Leo and I'm from Croatia. I'm a proud owner of this Sport Edition Scirocco for 4 moths now and this is my first car. So the specs are: 2011year, 1.4 twincharged petrol engine 160hp with manual gearbox and R-line exterior. It has the full black interior including black roof fabric and a panoramic sunroof, special blue and gray striped seats, RCD510 display and so on. The wheels are 18" Chicago Individual with Pirelli Cinturato p7 tires. For now I must say that I am very much satisfied with this car. Sorry for bad pictures and a dirty car in advance :) will change pictures over time.
If you have some mod ideas they are always welcome!
finetrond
Re: SCIROCCO SPORT EDITION 160 CROATIA :)
Post by finetrond »
Welcome to the flock. Nice car, good color. Unusual wheels which is good. most recommended mod for rocco is lowering.
I still driving my car with gravel Rally spec suspension.
Collector of warning lights.
Argonaut
Post by Argonaut »
Thank you! I was thinking of Eibach Sportline springs but they will have to wait as I'm sorting things out to order the front R bumper from xenonz.uk. Does someone know how can I smooth the headlight washer holes as I don't have any washers.
Argonaut
Post by Argonaut »
Big update:
Genuine Scirocco R facelift front bumper arrived.
It requires some repairing work and painting...
Pieces I've bought from local VW dealer which are needed for conversion:
1K8 807 184 C bumper bracket - 10€
1K8 807 183 C bumper bracket - 10€
1K8 953 041 H turn signal LED- 100€
1K8 953 042 H turn signal LED - 100€
1K8 805 567 B bonnet lock support - 20€
1K8 805 813 C support plastic part - 45€
1K8 807 241 D GRU tow hook cover - 15€
1K8 807 248 F front foam filler - 30€
2x 10W resistors for turn signals
R line old bumper for sale here
http://www.sciroccocentral.co.uk/forum/ ... 20&t=24661
Argonaut
Post by Argonaut »
Updates :) received rear facelift parts and got them painted
Also bought all necessary brackets, wires and connectors for conversion. Bought Inox exhaust tips.
Everything you can see is original VW.
Argonaut
Re: SCIROCCO EDITION 1.4 Facelift in progress CROATIA
Post by Argonaut »
FINALLY FINALLY
After a bunch of harassment with bodyshop, I finally got the parts fitted! So amazed with the new look of my car.
I am a bit sad that I couldn't find an R line rear FL bumper but it is what it is, I am very happy!
The things that were done:
1. New radio was installed, bluetooth and Mirrorlink working. Pics before and after:
2. Old bumpers, taillights and bootlid were removed... Front parts required for facelift were replaced and foam filler cut.
3. Facelift bootlid, front and rear bumper were painted in Candy White color to match my car. Rear diffuser was painted gloss black, as well as side mirrors. Bootlid got debadged and Inox exhaust tips are on :D
Outcome:
Argonaut
Post by Argonaut »
Roy_01
In: Sumatra
Post by Roy_01 »
Wow very nice job! What did the rear end concersion cost?
roc82
Post by roc82 »
Great progress!
All you need now is some facelift xenons, lowered ride height and some spacers for the wheels and it will look epic :)
Argonaut
Post by Argonaut »
roc82 wrote:Great progress!
Thank you my fellow driver :) Yes I am on for xenons, but they are extra expensive :(
And the car looks desperately high at the moment, like a goat :D
Argonaut
Post by Argonaut »
Roy_01 wrote:Wow very nice job! What did the rear end concersion cost?
Hey Roy!
Thank you, saw your amazing lane assist retrofit on yt :clap: and thanks for front bumper instructions
About the rear conversion, I bought boot lid, tails and bumper for 800eur in oryxwhite color in perfect shape from Germany and shipping ripped me off a bit. I changed side brackets only and bumper fits fine. Repair wires are bit of a problem, 12 are needed and 10eur is price for each. Found them on ebay for less. Now I am trying to make rear emblem boot opening to work.
Massive thanks to @rocky_rullez about that.
Roy_01
In: Sumatra
Post by Roy_01 »
Thank you! Ybby helped me with it. It was not that hard after all with his instructions.
But very happy with the lane and high beam assist and drowsiness defection.
Maybe im going to install side assist also but first new brakes $$$.
800 euro that is very cheap for all that parts! But shipping is expensive with that size/weights something you underestimate easily. Yes the repair wires are sometimes very expensive. I think it depends on how much they are selled. Then buying the pin terminals and wire seperately is a very big difference.
Ok good luck if you need a wiring scheme i can sent it to you.
I only have the front facelift but the rear is also very beautifull!
Roy_01
In: Sumatra
Post by Roy_01 »
Seems like E165 is the new rear lid switch.
It has a 2 pin connector.
Pin 1 connected to ground.
Pin 2 connected to T52a/13 of the BCM.
So first thing to check if you have a pin on this position on your bcm.
Argonaut
Post by Argonaut »
Thank you Roy, can you tell me what repair wire do I need for connector for bcm?
kpudgar
Post by kpudgar »
I also have the whole car facelifted and my trunk's badge also doesn't function a the rear lid opener!
immadnaaz
Post by immadnaaz »
Roy_01 wrote:Seems like E165 is the new rear lid switch.
@roy_01 is there a Way of getting in contact with you?, I can’t send you a Pm trough the forum, Maybe mail?
I need Some help with my Scirocco!
Greats Tom
immadnaaz
Post by immadnaaz »
Greats Tom
Roy_01
In: Sumatra
Post by Roy_01 »
LeoMarion wrote:Thank you Roy, can you tell me what repair wire do I need for connector for bcm?
I depends on the size of the terminal. You have to take a look when you remove the connector.
BCM rep. wire 000 979 009E is for the smallest pins
BCM rep. wire 000 979 025E is for the seconds smallest pins
Roy_01
In: Sumatra
Post by Roy_01 »
Greats Tom
Hi Tom i think your membership is to fresh to send pm's.
What do you need, the electrical drawings?
I haven't done the rear conversion myself only the front.
immadnaaz
Post by immadnaaz »
Greats Tom
i have joined 2016 tail lights and have them programmed, this is done with vag can pro. only I can not turn off the cold warm diagnostic, do I have to have another BCM for this? if yes which one?
