Bird poo!
true
Options: .
Heated Anthracite Leather
RNS-510 with 6 CD changer
17" Spa alloy wheels
Premium mats
Covered cupholder
Debadged rear
Cruise control
Bird poo!
Post by true »
Some baked on bird poo has ended up leaving a mark on the lacquer on my roof. I've tried claying it but it looks like the lacquer itself is damaged. Any advice?
Spiney
In: Pewter Grey
Options: Dynaudio, Cruise, DRL's turned off!
Just added Premium mats and treadplates, because she's worth it!
Re: Bird poo!
Post by Spiney »
Had the same thing with my Passat a few years back after it looked like an Golden Eagle had dumped on it! Unfortunately I never cured it. If anyone knows whether this is repairable without a respray I'd love to know how to do it.
The Kitchen Shop
http://www.just-cooking.co.uk" onclick="window.open(this.href);return false;
autoperfection
Re: Bird poo!
Post by autoperfection »
If the bird poo has etched into the lacquer there are two ways of removing it... you can either polish the marks out by hand, using something like Meguiars Sracth-X or a Fine Polish such as 3M Extra Fine or Menzerna Final Finish... and a lot of elbow grease!
Alternatively you can machine polish the marks out - this process will cut away the very top microns of lacquer, which will remove the etched in marks.
Hope this helps
Taryn and Jim :)
Re: Bird poo!
true, i've been speaking to Autoperfection over the same issue, our black GTI has been suffering a similar problwm more than the blue on the roc
true
Options: .
Premium mats
Covered cupholder
Debadged rear
Cruise control
Re: Bird poo!
Post by true »
Cheers guys. If I have a go with some polish is it just a case of polishing the area, or will the part I've polished end up looking different to the rest? Do I need to reseal it afterwards with anything other than wax?
Spiney
In: Pewter Grey
Re: Bird poo!
Post by Spiney »
Spiney wrote:Had the same thing with my Passat a few years back after it looked like an Golden Eagle had dumped on it! Unfortunately I never cured it. If anyone knows whether this is repairable without a respray I'd love to know how to do it.
I rather got the impression that the problem I had was that the acid in it it had worked through the laquer to the paint below. This is because I tried polishing (not waxing) it and it had absolutely no effect at all. Maybe wrong of course, often am!
The lesson I leaned was to get rid of it as soon as possible and not to buy a black car again!
The Kitchen Shop
