"Normal" oil temp
Simebaby
"Normal" oil temp
Post by Simebaby »
Hi All
Just wondered what the normal oil temp for a 2.0 TDI (170) should be. I've just had a thermostat replaced and so I've been checking the oil temps - once warmed up I'n running 92-95 when normal driving, up to 98-99 when putting the foot down, and when idling around 89-90. Temps stable after around 20 mins of driving (from cold). Just wondered if these seem ok or are they a bit low?
Si
Roy_01
In: Sumatra
Re: "Normal" oil temp
Post by Roy_01 »
Totally normal if you are talking about degrees Celcius.
Temps you are getting are perfectly normal. Mine varies between low 90s upto around 105 depending upon load and ambient temp.
timc
In: Pewter Grey
Options: Retro fit LED Mirror,Door Puddle Lights, Cruise. Kenwood DNX516DABS, Android box + Kodi, JL Audio amp, JBL GTO Speakers, Reversing Camera. Polar FIS+, XDS, Oscarli magic
Post by timc »
^^ mine too
xjay1337
Post by xjay1337 »
I get between 80 and 120 depending on driving conditions.
Anything up to 115-120 is fine. I wouldn't have it get higher than about 125 for extended periods personally but I've only ever had this sort of temperature on track.
click for build thread
Deagol
Post by Deagol »
I'd say your readouts are normal for UK driving under usual conditions. My TDi 170 tends to deliver these after 15 minutes of starting from cold so I'd say your car is like everybody else's.
The oil temp reading goes from "---" to "50" after about 7 to 9 minutes for me, depending on outdoor temperature and the weight of my right foot (although I refrain from giving it welly unless the engine is warmed up, to reduce wear damage through cold oil etc)
D
Baptised with Aerosmith
pokeiarda
Options: Celtic tuning remap
Post by pokeiarda »
I drive a golf and scirocco the temps look good i have slightly higher temp on the golf
Sent from my SM-G920F using Tapatalk
x.laura.x
Post by x.laura.x »
Good thread,
mine sits around 90- has touched 100 so I just slow down , :)
