VCDS cable eBay
brian2.0TDiblue
Options: Sports pack - RNS-510, Alcantara seats,
VCDS cable eBay
Post by brian2.0TDiblue »
Can anyone recommend a VCDS cable from eBay etc, I would like to get one without actually spending the full whack for the Rosstech version, like this one from eBay, if anyone could recommend one that would be great.
http://www.ebay.ie/itm/VAG-COM-VCDS-14- ... Sw7FRWat~c" onclick="window.open(this.href);return false;
thanks in advance
dimexi
Options: Parking Sensors
VAGCOM Mods:
DRL/PRL off
Needle sweep
XDS on
Big mph speedo
Alarm beep
Windows close via rain sensor
Other Mods:
Metal Pedals
Self installed Cruise Control
RNS510
Stage 1 Bluefin
Re: VCDS cable eBay
Post by dimexi »
Majority of people on here wouldn't usually recommend a non-legit cable. There has been at least one instance of someone causing problems with a module due to those cables on this forum (if I remember correctly).... However, I expect the next post below to tell you exactly where you can buy them :')
whiteDevil_170
revo stage 1 remap
Re: VCDS cable eBay
Post by whiteDevil_170 »
This topic is another that has been done to death.
I wish people would actually look at the section or search function.
As said above the majority of people including myself don't recommend using a cheap ebay cable. If something goes wrong what can you do about it. The cable doesn't get software updates like a genuine ross tech. And you don't get customer support either.
My opinion pay the money for a genuine cable.
Or find somebody to do the mods for you with one.
Jack
;) Lets Roc ;)
