Im looking at getting my 140 TDI to 200.
I know a stage 1 will get me to around 175 but is their anything else i could do thats fairly cheap to get the extra power.
Also if you do recommend anything should i do this before or after the map. thanks
Whats the most efficient way to get from 140 BHP to 200.
- Dubber13
Re: Whats the most efficient way to get from 140 BHP to 200.
My 140 tdi is currently at 196 last time it was on the rolling road.
The only engine mods it has is
Stage 1 map
Vwr panel filter
Stage 1 map
Vwr panel filter
Easiest way is to buy a 2.0TSI
Dubber13 wrote:My 140 tdi is currently at 196 last time it was on the rolling road.
Stage 1 map
Vwr panel filter
Are you sure thats all you've added? if so then it might cost me less than i planned
- whiteDevil_170
Grant_hewitt wrote:Dubber13 wrote:My 140 tdi is currently at 196 last time it was on the rolling road.
Stage 1 map
Vwr panel filter
Are you sure thats all you've added? if so then it might cost me less than i planned. I just thought to get to 196/200 i'd have to add more than just the map and filter.
My opinion you would need more than that. 140 stage 1 your looking at around 170 -180 if your lucky and an optimistic rolling road. And a panel filter adding 20bhp? Lol I don't think so.
My 170 with stage 1 revo is running 205 based on revo figures.
So how can a 140 go to 200 if my 170 only just gets it. And I already have 30 bhp on a 140.
Jack
Lets Roc
- In: Shadow Blue
You are correct.
196bhp from a 140 engine isn't going to happen with just a map and filter. The turbo just won't flow it.
- Roy_01
You didn't remove your dpf and put another downpipe on it? And how much does it smoke on full load?
A renomated remapper i know over here reaches 185 bhp and 415 Nm after removing the dpf and putting a new downpipe on it. (stock 140 bhp).
And 163, 170 and 177 bhp are getting remapped to 205 bhp and 430 Nm, just what Jack says.
- I drive a: R-Line
Sell it, buy a 170/184 tdi. That's the cheapest way to get to get a 200bhp derv.
