Hi all,
I have found a replacement wing mirror, the seller says the mirror is heated and electic adjust. My current mirror has the folding option. Is this enabled using VCDS or do I need to keep looking for a mirror with this option?
Thanks in advance.
Wing mirror replacement
- charliegilmanuk
Re: Wing mirror replacement
If only it was that easy, it's a different part ![Smile :)](./images/smilies/smile.gif)
Is this something I can salvage from my old mirror and put in the new?? Cheers
- wensleydale
How badly damaged is the original mirror, and what side of the car was it on?
Overall i can live with it, but in the long run it needs replacing. Chunk out of the indicator strip, cracked white plastic cover and a big bit of black plastic casing is missing.
- wensleydale
providing all that damage is on the bit of the mirror that folds it should be a relatively easy fix. It sounds like all you need is a new lower housing (~£27) and a mirror cap (~£35 +paint). Here are a couple of links with how to take the mirror apart:
http://www.sciroccocentral.co.uk/forum/ ... 37&t=14719" onclick="window.open(this.href);return false;
http://www.sciroccocentral.co.uk/forum/ ... 79#p146879" onclick="window.open(this.href);return false;
Thats brilliant news! Yes all damage is on the mirror, no base damage. Thanks for the help!
