Replacing Audio System
I have the standard display in my Scirocco.
It doesn't have bluetooth or satnav, I just wanted to know being a complete mong, is there a chance I can replace the audio system so it has bluetooth and satnav built in already?
Help would be greatly appreciated.
thanks Zina
thanks Zina
- Phil
- In: Night Blue
Re: Replacing Audio System
If you want it all built in rather than running the cables around for the bluetooth etc then you need the RNS315.ZinaZonic wrote:I have the standard display in my Scirocco.
thanks Zina
Straight forward swap out, might need someone to code in the satnav to your speedo display tho but plenty of people on here would be willing to help you there
Phil
Thanks phil
really appreciate the reply!
Whats the difference between the RNS310 and the RNS510???
The RNS510 has a bigger display
- whiteDevil_170
And has dvd play in motion so can watch dvds.
also has a hard drive so can store music.
Jack
Lets Roc
- Phil
- In: Night Blue
The RNS510 is the superior Radio but the RNS310 is still a great bit of kit. The best part of the RNS315 is the bluetooth is built into the until, as with the RNS it's or RCD you require module box aswell, which goes under your seats (or in my case behind the Climate Control) and run the cables around.
Phil
So I could have the RNS510 installed into my car quite easily. I prefer the bigger display as I have it already.
Looked at prices for the RNS510 and its decently priced, all I need now is someone to install it!
Thanks for your help everyone
- Roy_01
RNS510 is also very populair by thieves. You can't remove a panel like some aftermarket devices. You can install a navilock or just take take a good insurance.
- Phil
- In: Night Blue
No problem, just rember Bluetooth is separate!ZinaZonic wrote:So I could have the RNS510 installed into my car quite easily. I prefer the bigger display as I have it already.
Looked at prices for the RNS510 and its decently priced, all I need now is someone to install it!Thanks for your help everyone
Phil
Wow I'm a retard, so the RNS310 has the bluetooth built in, whereas the 510 doesn's have it built in?
- Phil
- In: Night Blue
Yep that what I meant by the unit under the seat mate haha. The Bluetooth is between 150 - 200 quid to buy
Phil
