Check deadlock?
- Wiz1987
Check deadlock?
Hi guys,
Just picked up my new roc and when I turn off the engine I notice it says in the MFD "check deadlock, owners manual"
I assume this isn't normal?
Car is under warranty so just want it fixed and to go into dealer with some knowledge on the issue
Anyone here experienced it?
Car also told me to check third brake light but then went off after engine on and off ... Not check if it's working yet as I was busy but will tomorrow ... Bloody wiggly amps
Roc on!
- whiteDevil_170
Re: Check deadlock?
It is normal and happens every time you turn ignition off and take the key out. It's so that you don't deadlock the car with somebody still inside. When deadlocked the door handles inside won't work so anyone stuck inside would have to smash windows to get out. I believe that's what it is anyway. Been a while since I have seen this asked.
Last edited by whiteDevil_170 on Mon Apr 20, 2015 9:05 am, edited 1 time in total.
Jack
Lets Roc
- Phil
- In: Night Blue
Re: Check deadlock?
Cant say i've seen this in mine to be honest....? Manual car?whiteDevil_170 wrote:It is normal and happens every time you turn ignition off and take the key out. It's so that you don't deadlock the car with somebody still inside. When deadlocked the door handles inside won't work do anyone stuck inside would have to smash windows to get out. I believe that's what it is anyway. Been a while since I have seen this asked.
Phil
- whiteDevil_170
Re: Check deadlock?
I'm not sure when it was introduced or if it's manual only. Wouldn't of thought it would be restricted to manual.philjay92 wrote:Cant say i've seen this in mine to be honest....? Manual car?whiteDevil_170 wrote:It is normal and happens every time you turn ignition off and take the key out. It's so that you don't deadlock the car with somebody still inside. When deadlocked the door handles inside won't work do anyone stuck inside would have to smash windows to get out. I believe that's what it is anyway. Been a while since I have seen this asked.
My car is a sep 2012.
Jack
Lets Roc
Re: Check deadlock?
That comes up on mine as well, mines Is dsg
Re: Check deadlock?
I got my car yesterday and was wondering the same thing. Is a DSG Scirocco R! 2013
- selleym
Re: Check deadlock?
59 Rocco doesnt do it. But my 12 Seat Ibiza Fr does it. So must have started between 2010 and 2012
- whiteDevil_170
Re: Check deadlock?
http://www.sciroccocentral.co.uk/forum/ ... k+deadlock" onclick="window.open(this.href);return false;
http://www.sciroccocentral.co.uk/forum/ ... ck#p130207" onclick="window.open(this.href);return false;
http://www.sciroccocentral.co.uk/forum/ ... t=deadlock" onclick="window.open(this.href);return false;
Jack
Lets Roc
- selleym
Re: Check deadlock?
Bored at work?whiteDevil_170 wrote:http://www.sciroccocentral.co.uk/forum/ ... k+deadlock
- whiteDevil_170
Re: Check deadlock?
Extremelyselleym wrote:Bored at work?whiteDevil_170 wrote:http://www.sciroccocentral.co.uk/forum/ ... k+deadlock
Jack
Lets Roc
- Wiz1987
Re: Check deadlock?
Hello,
Googled it and it was exactly what a few people have mentioned relating to reminding you the car has a deadlock lol
Sorry I just assumed it was a fault as it says check owners manual with exclamation marks!!!
Bit dramatic VW
Bit dramatic VW
Roc on!
