RNS510 fitting
rafail7
I drive a: 1.4 TSI 122/125
Options: 30-35mm H&R lowering springs
19" Calibre Altus Matt Black Alloys
All white interior LED's
Red LED footwells
Yeti tips
Dectane DRL's
Number plate LED bulbs
RNS510 fitting
Post by rafail7 »
So I want to fit RNS10 to my Scirocco and I was looking at this one:
http://www.ebay.co.uk/itm/NEW-VW-RNS510 ... 3cde745c4c" onclick="window.open(this.href);return false;
So if I do get it is it an easy swap? Ive seen the video of the fitting (" onclick="window.open(this.href);return false;) but is this all I have to do and everything works fine or is there more to it?
dimexi
Options: Parking Sensors
VAGCOM Mods:
DRL/PRL off
Needle sweep
XDS on
Big mph speedo
Alarm beep
Windows close via rain sensor
Other Mods:
Metal Pedals
Self installed Cruise Control
RNS510
Stage 1 Bluefin
Re: RNS510 fitting
Post by dimexi »
it should be plug and play. I suspect you have an RCD510 in your vehicle already? The plugs should be the same.
You might need to recode your MFD to display nav info, but this isnt essential if you dont want it
rafail7
Red LED footwells
Yeti tips
Dectane DRL's
Re: RNS510 fitting
Post by rafail7 »
dimexi wrote:it should be plug and play. I suspect you have an RCD510 in your vehicle already? The plugs should be the same.
Yeah I have the RCD510 atm, Im guessing I still have to add that extra wire for the sat nav like the guy did in the tutorial?
dimexi
VAGCOM Mods:
DRL/PRL off
Needle sweep
XDS on
Big mph speedo
Alarm beep
Other Mods:
Metal Pedals
RNS510
Stage 1 Bluefin
Re: RNS510 fitting
Post by dimexi »
I didnt watch the tutorial. I assume your RNS will come with a GPS antenna. You can plug it in and mount it just under the vents - there might be a video for the vents somewhere. Taking them out can be a pain
