Other than adding CoCopops <select cereal of choice> how do I remove the rear bench?
Hmmm no wonder you only drive a 122Lewis Miller wrote:Set the seat on fire the heat will cause he milk to scald then it can be easily removed.
Thanks Les, I'll give that a go, much appreciated.lesvw123 wrote:If you have cloth seats gets some bicarbonate of soda pour over the spilt area and leave it for two or three days then vacuumn it and it will have absorbed the milk
Hope this helps
Yeah, valeting's the option if bicarbonate doesn't do the trick, that or chop it in for a 2.0TSImoulin12 wrote:Having split much less than a litre of milk in my old car, I would strongly advise you carry on looking for info to remove the rear seats and very other affected part that's removable, in order to clean. Bicarbonate of soda does help, but it's no cure all, and the stink that old milk leaves behind will make you want to sell the car! Be careful with how you clean any cloth upholstery and carpet, to avoid piling. Myself, I'd swallow the costs and get the car to a reputable detailer / valeting company to get the job fully done, using the right chemicals, and with a minimum of damage to the interior. May sound dramatic; but just writing from experience.
Is it that simple to pull the bench out? yes it's soaked in to the base not the back. I thought you had to undo some torcx screws to get it out or is that the backs? Can't see any under the seat base. Thanks for the advice.jackhay wrote:Assuming it's the seat base that's wet and not the backs, it's very easy to remove. Get both hands under the front edge, pull forward and upwards, the front comes away and the whole thing can be pulled out. It's just clipped in place. (Whilst it's out you can fit sound insulation under there as I did - makes quite a difference.) In the standard car there is just painted metal under the seat base and if you have milk sloshing around this is where it will be. If the seats have absorbed it all then get them out of the car and do the treatment others have suggested, outside of the car, and let them dry outside the car too.
This is the best advice you have had, again based on my own experience.moulin12 wrote:Having split much less than a litre of milk in my old car, I would strongly advise you carry on looking for info to remove the rear seats and very other affected part that's removable, in order to clean. Bicarbonate of soda does help, but it's no cure all, and the stink that old milk leaves behind will make you want to sell the car! Be careful with how you clean any cloth upholstery and carpet, to avoid piling. Myself, I'd swallow the costs and get the car to a reputable detailer / valeting company to get the job fully done, using the right chemicals, and with a minimum of damage to the interior. May sound dramatic; but just writing from experience.
YorkRoc, you have probably tried it anyway by now, but yes, it really is that simple to remove the seat base. No tools are needed. The back is harder.YorkRoc wrote:Is it that simple to pull the bench out? yes it's soaked in to the base not the back. I thought you had to undo some torcx screws to get it out or is that the backs? Can't see any under the seat base. Thanks for the advice.jackhay wrote:Assuming it's the seat base that's wet and not the backs, it's very easy to remove. Get both hands under the front edge, pull forward and upwards, the front comes away and the whole thing can be pulled out. It's just clipped in place. (Whilst it's out you can fit sound insulation under there as I did - makes quite a difference.) In the standard car there is just painted metal under the seat base and if you have milk sloshing around this is where it will be. If the seats have absorbed it all then get them out of the car and do the treatment others have suggested, outside of the car, and let them dry outside the car too.
Hi Jack,jackhay wrote: YorkRoc, you have probably tried it anyway by now, but yes, it really is that simple to remove the seat base. No tools are needed. The back is harder.
Hi Bob,Cuprabob wrote:A new one from TPS might not be as expensive as you think, especially if it's cloth.
In theory yes, but many will sell direct to the public. It's never been brought up at my local branch whenever I've bought anything.YorkRoc wrote:Hi Bob,Cuprabob wrote:A new one from TPS might not be as expensive as you think, especially if it's cloth.
Thanks for your reply, isn't TPS for trade only though?
