Common Windscreen Rattle
- selleym
Is this the windscreen rattle? Hoping someone who has had the same might be able to confirm.
I know the camera is pointing at the vents but the sound is coming from around the little sensor on the dash by the window.
https://onedrive.live.com/?cid=ac833d10 ... xevRR9jf3s
- whiteDevil_170
Re: Common Windscreen Rattle
Sounds very similar to a rattle I had when I 1st got my car. It seems to disappear and return now and again. It happened the other day actually.
Jack
Lets Roc
I have the same (...we meet again...). is this of any help? http://www.scirocconet.co.uk/forum/dash ... 10998.html" onclick="window.open(this.href);return false; and http://www.scirocconet.co.uk/forum/dash ... -t374.html" onclick="window.open(this.href);return false;
- selleym
Yes exactly the same for me sometimes its their randomly and then can go away for weeks then bam its backwhiteDevil_170 wrote:Sounds very similar to a rattle I had when I 1st got my car. It seems to disappear and return now and again. It happened the other day actually.
- selleym
Haha oh dear we both seem to have the same rattles! Will have a read through those two posts and report back! Cheers for the infomoulin12 wrote:I have the same (...we meet again...). is this of any help? http://www.scirocconet.co.uk/forum/dash ... 10998.html" onclick="window.open(this.href);return false; and http://www.scirocconet.co.uk/forum/dash ... -t374.html" onclick="window.open(this.href);return false;
- selleym
Attempted to Fix my windscreen rattle today.
Fingers Crossed!
Fingers Crossed!
- whiteDevil_170
what did u do?selleym wrote:Attempted to Fix my windscreen rattle today.
Fingers Crossed!
Jack
Lets Roc
- selleym
Followed this from RW1
http://www.sciroccocentral.co.uk/forum/ ... tle#p68218
There was already the Velcro in there but was looking at bit worse for wear.
So I added in some anti rattle tape.
I could reproduce the rattle by pushing down on the wiper in the center of the windscreen. After pushing stone anti rattle tape up there seems to have gone! Only time will tell though!
If my fix doesn't work be off to the dealer for them to do it properly. Should be covered under warranty if you give the TPI.
hi,
has there been any development on this front?
this rattle has been doing my head in to the point that i've actually considered selling the car completely!
thanks
thanks
- selleym
Mine has come back this week
I need to do it properly this time clearing out all the old stuff.
Just follow the link on my post above.
- Andy Rocc
So that's what,the annoying sound is, been bugging me for 12 months!
- Irvysan
- I drive a: R-Line
- In: Ultra Violet
Soundaktor?
Sent from my LG-D855 using Tapatalk
- selleym
Quite easy to tell if it's the windscreen rattle.
Grab the windscreen wiper that's base sits in the middle of the windscreen. Then grab the base.
Move it up and down (Away from and towards the windscreen)
You will hear the tapping noise.
- I drive a: R-Line
My three week old R Line is going back to the dealer in two weeks due to a rattly the windscreen [FACE WITH LOOK OF TRIUMPH]
Sent from my SGP521 using Tapatalk
I used about a metre of anti vibration tape today around the scuttle panel. Hopefully the rain will ease enough tomorrow so that I can listen out to see if I've cured the rattle.
I had the same on mine the noise was come from the rear view mirror where it mounted on the screen.
Nope, that didn't work. Have been pressing down on the scuttle panel cover today to locate any noise. Have ended up deadening the passenger side by the windscreen pillar. Will see if this has solved it tomorrow. Have also greased all of the moving parts of both wipers.neilwarren wrote:I used about a metre of anti vibration tape today around the scuttle panel. Hopefully the rain will ease enough tomorrow so that I can listen out to see if I've cured the rattle.
From inside the cabin, the rattle seems as if it is coming from the dash panel with the climatronic temp sensor (square box in center of dash by the front windscreen). By pushing down on it, I can hear the rattle/tapping sound, has anybody had this same issue? I don't suppose this would have anything to do with the plastic plate underneath touching the glass of the windscreen? I've taken the car to the dealership twice now and they have not been able to fix it and advised that they would need to pull apart the dash - not too keen on this option as i fear that it may introduce further rattles
- I drive a: R-Line
My car has been with the dealership since 25th August. They still can't fix the fault. They've replaced so many parts but to no avail as yet. I'm on holiday until 7th September, so I'm hoping it's fixed on my return.
Fingers crossed I seem to have sorted the bottom centre windscreen rattle. The rattle was coming from two places under the scuttle cover. These were under the passenger side, one where a clip attaches and one where the scuttle cover sits. I padded both of these parts out with anti-vibration tape and have not had a squeak since.
