Hi all, My boot release will not open fully on the first press on the key fob or boot release in drivers door, second press on either does the job, any idea what's gone wrong?
Regards
Boot release
Re: Boot release
lloydie63 wrote:Hi all, My boot release will not open fully on the first press on the key fob or boot release in drivers door, second press on either does the job, any idea what's gone wrong?
Regards
Mines the same, sometimes takes multiple presses.
2011 1.4 TSI 160 in Rising Blue with DSG box
http://www.sciroccocentral.co.uk/forum/ ... 13&t=17326" onclick="window.open(this.href);return false;
Re: Boot release
Just push / pull the button for a big longer and it should work OK.
Re: Boot release
Cheers both will give it a try once it stops raining
Re: Boot release
Ok tried long press on boot release key fob and again on the release in the door panel and no difference. The boot lifts slightly but I still cant open the boot by hand unless I repress the keyfob/door release again.
Re: Boot release
If it's lifting slightly but not releasing then the issue is probably the bump stops either need adjusting or replaced.
Re: Boot release
All sorted and working correctly. Bump stops fitted to the boot are spring loaded, one of the bump-stops was pressed in, a simple twist and stop is now "out"
Re: Boot release
Glad it was a nice easy fix:-)
Re: Boot release
