Hi
Does the standard head unit play wma (windows media audio) files from CD of SD card? I presume it plays mp3 but wondered about wma???
I'm just loading up a 8GB SD card ready for 2 weeks time...!
Many thanks
Chris
RCD510 wma compatible?
Re: RCD510 wma compatible?
Haven't played any wma files myself but the manual says it does
mine is, but only upto a certain bitrate - 320kbps from memory ?
- jonallen628
Variable Bit Rate WMA's work also which should technically be the best quality WMA as the compression varies according to the complexity of the music. The ceiling on WMA VBR i believe is 355 kbps using the rip function on Windows Media player.
Black is the new Black....
The head unit will play MP3 and WMA files from the SD Card - You can also play ACC and OGG-Vorbis encoded files via the MDI interface (from USB device or iPod) I have a MP3, WMA and OGG files on a 16gb USB stick in the armrest.
- silver130
I have wma files @128kbps on a SD card with no problems. Also use the same set up on a USB memory stick with no probs either.
IF IT'S NOT BROKEN
I'VE NOT TOUCHED IT YET !!
