Oil on the turbo
eikido
Options: Built 2008-08, currently around 22000 miles (2013-08-02). Manual.
Oil on the turbo
Post by eikido »
I have an oil leak on my turbo. I see oil on the turbo intake hose from above in the engine compartment, and from below, the "cool" side of the turbo and nothing on the hotside going out as exhaust.
I've read its a bit common with oil coming from the crankcase ventilation hose and in to the inlet of the turbo. But i find it to be a little to much around most of the turbo.
I couldn't see any oil leak on the oil pipes going in and out of the turbo and engine block EXCEPT for the pipe with oil going in to the turbo as i have to remove the tire to see if there is any oil coming from there.
What can it be?
Is it the same for you guys?
eikido
Re: Oil on the turbo
Post by eikido »
Its probably the Crankcase ventilation
Thanks the crankcase ventilation input at the intake hose on the turbo
What do you guys think?
rsh3ll
Post by rsh3ll »
Sorry for bringing up an old thread but did you get this fixed ? Have exact same issue....
