I know that it is possible to mod the firmware with language but offcourse this is easy since you "just" have to translate all the text of a language you dont use the the one that you wish to have instead, but i dont know if it would be possible to change the interface setup. You have the same navigation methods on the Composition Media as an RNS510 (touch screen and the buttons are the same). There will offcourse be some other hardware in the Composition Media but shouldnt the RNS510 be able to run an interface like the Composition Media with the hardware it got?
I dont know if the Composition Media runs a completly different programming language, if it has some different chips, but my thought was that you might could grab some interface coding from the Composition Media firmware and splice it with the RNS510 firmware. Any one have any insight in this? or am im completly crazy
