Is any one running 100w bulbs?
kanedingle
Post by kanedingle »
Hi guys, is anybody running 100w bulbs?
Is it safe? Or will it mess up the canbus system?
As I was running an aftermarket hid kit and it ruined something under the dash to do with the cambus and was pritty expensive to fix. So don't want it to happen again :)
Ty
Skollers
Options: ECU Remapped to 175bhp
Bluetooth (OEM)
Cruise Control
Parking Sensors
Upgraded bulbs
Re: Is any one running 100w bulbs?
Post by Skollers »
I've been running 100w in my dipped beam for a yr now, no issues ?
2009 2.0gt tdi 140bhp
2003 Suzuki Gsxr 1000 Rizla green/yellow (My baby) !
kanedingle
Nice 1 skollers, thanks for the reply dude
Just feel abit better knowing people are running them with no issues :)
whiteDevil_170
revo stage 1 remap
Post by whiteDevil_170 »
Iv heard of people using 100 watt bulbs and it causing the wiring to melt causing problems. There was a thread I read a while back that the late rw1 posted in about why not to use 100 watt bulbs. Can't remember title. Person ally I wouldn't use them. Why do you want/ need 100 watt bulbs?
Jack
;) Lets Roc ;)
kanedingle
It's just a case of I got offered some by a friend
But was unsure. Didn't want it to mess up the cambus system again
What are the standard bulbs 55w?
whiteDevil_170
revo stage 1 remap
Just found the post I mentiond..
RW1 wrote:Goodness............. :eyepop:
Having worked in the aircraft manufacturing industry at the sharp end of developing designs and integrating them into aircraft, these lamps are most likely specified for a specific installation. Until one knows the rest of the helicopter design, you cannot say these are like for like. eg. What is the expected heat dissipation rate? What heat is the reflector taking away from these lamps as part of the design? What shape is the reflector (affects filament position in the bulb)? How many running hours is expected? The fact that they are similar "car" lamps bears no parallel and shouldn't be assumed.
I'll just leave this thought here...... this is a VW which I was asked to repair 4 years ago. It had direct connection high power lamps rather than the load passed through a relief relay circuit from the battery. The problem didn't manifest itself straight away. The guy was lucky in the end that he didn't have a dash board fire which couldn't be easily accessed. The only way of stopping this particular incident was disconnecting the battery. The circuit had eventually end up being "un-fused" through a multiple failure that changed the circuit current flow paths because the switch had melted and changed shape inside.
This was the state of the front lights loom with the wire melted into several other wires next to it. Fortunately in this case the loom was short in length and only went from the fuse-relay panel to the headlight switch. All inside the dash area, so extraction for repair was fairly easy.
By all means increase the lamp whiteness/brightness with car lamps from Osram, Philips, Razo's etc., but not at the expense of drawing extra current (ie. above 55watts) and roughly doubling the amps drawn.
And............ this guy hasn't returned to his posting to tell us what lamps he fitted that caused the reflectors to melt in his Scirocco.
http://www.sciroccocentral.co.uk/forum/ ... lit=+watts" onclick="window.open(this.href);return false;
I hear no relay "clicks" when the my Scirocco's lights are switched on, so I can only conclude until I see a circuit diagram, that the lamp switch is taking the full whack of what may be switched on. Contacts inside these switches are not big, are quite delicate and designed for what is normally expected plus a little. A failure is not necessarily a burn out as above illustrates. Once the switch fails, who knows what it will "reconnect" into the circuit which you may have no control over.
Jack
;) Lets Roc ;)
kanedingle
Thanks for that mate. Your post has just made my mind up for me :)
whiteDevil_170
revo stage 1 remap
No worrys. :) Thought I'd give you my advice as I wouldn't want you to have a similar problem..
Jack
;) Lets Roc ;)
kanedingle
Cheers dude. Don't want anymore problems with lights
robinalex
I drive a: GTS TSI
Options: Cruise control
Pano Roof
RNS315
Winter pack (heated seats / headlight washers)
Tyre Pressure Monitor
Electric seats
Parking Sensors
Bi-Xenon headlights with cornering lights
K&N filter
H&R 35mm
12.5mm Black anodised hubcentric spacers
Milltek Non-res catback
R-Tech Stage 1
Post by robinalex »
My dad is a retired auto electrician and he had loads of people through his workshop with melted wiring problems after running 100w bulbs, also illegal. I would stay well clear
biteme
Post by biteme »
get some Ring Xenon Ultimas they give out 120% more light. http://www.autobulbsdirect.co.uk/ring-x ... bulbs.html" onclick="window.open(this.href);return false;
whiteDevil_170
revo stage 1 remap
biteme wrote:get some Ring Xenon Ultimas they give out 120% more light. http://www.autobulbsdirect.co.uk/ring-x ... bulbs.html" onclick="window.open(this.href);return false;
Surposdly they do. I doubt they actually do though.
Jack
;) Lets Roc ;)
ZephyR
Post by ZephyR »
I wonder if they sell perpetual motion machines as well.
biteme
Post by biteme »
Ring are a large company and Osram have bulbs with the same output, legally they cannot market a bulb without proof in lumens that it meets that. No harm in being a pessimist just means you can live in the stone age with tech :P
Chillout
Options: 1.4TSI Stage 1++(~220BHP), sunroof, 18" Interlagos, black interior rooflining, premium leather multifunctional steering wheel, electronic mirrors, tinted rear windows, footwell lighting, fog lights, coming/leaving home, mats, smokers pack, media-connection, cruise control and lots more...
Post by Chillout »
I used to have 100W bulbs in my Roc, and the fitting melted because of the heat...
dimexi
Options: Parking Sensors
VAGCOM Mods:
DRL/PRL off
Needle sweep
XDS on
Big mph speedo
Alarm beep
Windows close via rain sensor
Other Mods:
Metal Pedals
Self installed Cruise Control
RNS510
Stage 1 Bluefin
Post by dimexi »
Going from 55W to 100W without wiring changes should definitely ring alarm bells anyway. The extra power has to come from somewhere, and you bet the wires won't be able to cope. Bypassing fuses and relays is just asking for more trouble.
Excellent post from the late RW1. He definitely left a goldmine in this forum
