GT 170 Remap / Clutch Issues?
Been doing some research into a stage 1 map on a GT 170 TDI, read some were that you can have trouble with the clutch slipping due to increased torque & BHP but only on manuals? How true is this if so does that mean your better with DSG? If so why does it have problems on manuals but not DSG?
Re: GT 170 Remap / Clutch Issues?
I am by no means an expert on this - but I do have some mechanical knowledge. It makes sense in my mind - if you have a ridiculous increase in torque (percentage wise), it is possible that the clutch + flywheel combo wouldnt be able to handle it as well. It will probably cause excessive wear too.
So, it depends on how high your increase is going to be. I know a few people who have done engine mods on other cars, but they ALWAYS swap out the clutch for a high performance one. Why don't you do that?
Also, it is not entirely impossible for the automatic clutch on the DSG to slip too because of the same reason - however, it might be less noticable
DSG can handle all the torque a standard turbo can offer. Manual boxes can slip after stage 1. Luck of the draw unfortunately
Gray
Gray
