I've just purchased the latest bluetooth unit (76P*L) to replace my current 3C8*L, due to its better implementation of A2DP/AVRCP, and the fact I can finally control music from my streaming iPhone via the MFSW. All good...
However, as the previous unit had A2DP streaming, I figured I could re-use the current harness and swap just the boxes.. seems logical.
Upon doing so, its all working a treat except no sound when in A2DP mode. I'm wondering if the harness has different pin outs compared to the old unit, although the carsystems.pl site suggest you can use the same harness for both models.
Wondering if anyone here could shed any light on what to check? I'm surprised if the harness needs updating, especially as the previous unit's A2DP audio gave sound, makes me think they might have changed the pinouts? I could swap the harness over, but it will require some changes around my mic wiring, which I'm not sure I'm technically good enough to attempt right now!
Martin
