A few niggles
A few niggles
Hi folks,
Got my scirocco a few weeks ago (used, 3 years old) and i've had a few niggles with it.
First is the annoying rattle coming from the back, so from searching the forum this seems to be related to the Tailgate - so i'll have a go at sorting this myself.
Now the second niggle which I couldn't really find much on was relating to the driver side window. The seal between the window and the door, for appox 5cm from the door sil up the window doesn't quite press against the window. This results in a bit of noise (as in, can hear other cars passing) on the motorway, and, quite comically, getting soaked when someone with a pressure washer sprays the window!
Now the seal looks perfectly intact, isn't deformed in anyway.
Has anyone else experienced this? The seal is hollow so I was thinking maybe pierce a small hole in it and fill it with some sort of foam to pad it out at the bottom?
Thoughts?
cheers
Thoughts?
cheers
Re: A few niggles
I get this on the passenger side with the Mrs constantly saying she can hear a lot of wind noise (but not feel it, oddly). Also getting a really really infuriating rattle from that door in particular.
No idea how to fix it I'm afraid but at least you know you're not the only one. Ill have it in the dealers at some point and see what they do with it.
Re: A few niggles
I get the same, wind roar from the drivers side but no wind, the dealer says it's ok and to the correct tolerance but he doesn't have to live with it. Personally I think it's all to do with the frameless design which quite honestly I don't see the point of in a hardtop, it's not even as if a soft-top is an option.
Re: A few niggles
It's bloody annoying! Just got home to try and sort the tailgate rattle and realised the one alan key i'm missing is the size i need. Typical.
Re: A few niggles
Ok so the creak is definitely coming from the offside tailgate boot opening thingymagic, as i can hear it if i press the boot on the outside. Sounds like it needs replacing rather than adjusting tbh, it's squeeky all the way down when you press it
Re: A few niggles
Yeah I replaced mine recently and sorted the noise.stono wrote:Ok so the creak is definitely coming from the offside tailgate boot opening thingymagic, as i can hear it if i press the boot on the outside. Sounds like it needs replacing rather than adjusting tbh, it's squeeky all the way down when you press it
Part number 1K8827761D around £5 each.
Re: A few niggles
Brill, where did you order the parts from mate?carlpea wrote:Yeah I replaced mine recently and sorted the noise.stono wrote:Ok so the creak is definitely coming from the offside tailgate boot opening thingymagic, as i can hear it if i press the boot on the outside. Sounds like it needs replacing rather than adjusting tbh, it's squeeky all the way down when you press it
Re: A few niggles
£4.22 + VAT from VW main dealer.
Re: A few niggles
And for those who are interested... fitted it in 5 minutes = rattle completely gone woo hoo!!
Re: A few niggles
That's good to hear. I found them a tighter fit than the old ones as the rubber gasket was thicker so took some force to fit them!
Re: A few niggles
Yeah i had to draw on my superman grip as I didn't have a wrench big enough hahacarlpea wrote:That's good to hear. I found them a tighter fit than the old ones as the rubber gasket was thicker so took some force to fit them!
