Front left fog light not working?
Le Clue
Options: Panoramic Sunroof, Xenons, PDC, TPM, Vienna Leather, Electric Seats, Folding Mirrors, Light Package
Post by Le Clue »
Hi all,
I installed HID fogs on my Scirocco and the following day the left side fog did not come on. So I got a new bulb, swopped ballast..still not working. Then I tried out the original bulbs and still the left hand side does not come on.
When it first stopped working I got a bulb out error..I cleared it over VCDS but a week later trying to find the fault the bulb out error does not come on even though the bulb does not go on.
So could it be a fuse? Which fuse is for the fog lights? Could it be something on VCDS?
This is on my 2 week old Rising Blue 2.0TSI :(
Current:
'12 Rising Blue VW Scirocco GT 2.0TSI
/DSG/Xenon/Panoramic Sunroof/PDC/
/REVO 2/APR Carbonio Stage 2/Flowtech DP/R8 Coilpacks/Lamin-X/LED's/HID Fogs/RNS510/9WZ Bluetooth/Bilstein B14 Coilovers/REVO Insert/19" Savannah/Polar Fis +/
RW1
Legend
Hi from Sunny Stopfordia
Re: Front left fog light not working?
Post by RW1 »
There is no separte fuse or fuses for the fog lights but it may be worth looking at fuses 2 & 13 (10 amps each) in the side of the driver's dash which control lights.
If you have set VCDS up and it worked. . You may have blown the Central Electrics controller's output circuit for the the left fog light..
29 Oct'09 at dealers
Driving 4th Nov. Sorted!
Le Clue
Post by Le Clue »
I have done VCDS coding but nothing regarding the fogs except for the error I cleared..
Current:
Le Clue
Post by Le Clue »
Disconnected the battery...it's working again :)
Current:
