wel... basically iv had my key through the washer and drier (not a massive problem because i have a spare) but id like to fix it or get a new 1 programmed, when i put in in the ignition the lights come on and it starts for 3 seconds and says no key found or no chip found, my dealer says they will have to reset the computer and the new key, does that mean my revo map wil be deleted? i have a sps switch if i plug it in save the map then plug it in after the computer has been reset wil it still have the info for my sps switch again? basically i dont want to get a new key if it means loosing my re map? what are my options?
The key has to be recoded to the ecu, you shouldn't lose your remap, if for some reasothe dealer manages to wipe it the Revo dealer who installed it will re-instate it without you paying for a new remap. The sps doesn't save the map into the switch, it only switches between maps in the ecu.
Life's too short to go slow
Skoda Yeti 4x4 Elegance 2.0CR
