Which Bluetooth
NastyNick83
Options: Heated leather seats, Bi-Xenon, panoramic roof, Dynaudio, DAB, Rear parking sensors, Bluetooth
Which Bluetooth
Post by NastyNick83 »
Hi guys,
Sorry - I know this has been covered to death, but I can't find a definitive answer as to which module I should go for...
I have a 59 plate Scirocco GT with the RCD510 (I think that's right - DAB but no SatNav) and white MFD.
Currently does not sync with my iPhone (not compatible) so strongly suspect I have the old rcrap module.
Searches reveal 2 main modules and I can't fathom what the differences are or if only one of them will work?
9W7 7P6035730C
or
5N0035730D
Actually, I think I've just realised as I type the difference. Is the 9W7 for the SatNav unit and the 5N0035730D for the non-SatNav?
Nick
ayeaye
Options: Candy White Scirocco - August 2009 - March 2013
Now replaced with a MINI Cooper S
Re: Which Bluetooth
Post by ayeaye »
Either can be used with RCD510 and RNS510 - the 5N0 unit is a newer unit and would be the one I would go for if I was replacing a rSAP unit.
mickwillow
Options: Vienna Leather
Bi Xenon Headlights
Winter pack
Metal Pedals
Lux Mats
VW Individual Sills
DAB Radio
Dynaudio Premium Sound
Interlagos 18's
Parking sensors
Electronic folding mirrors
Eos's rear drinks holder
Golf rear vents
VW BT
Re: Which Bluetooth
Post by mickwillow »
NastyNick83 wrote:Hi guys,
9W7 7P6035730C
or
5N0035730D
Thanks Nick
Fitted the 9W7 7P6035730C unit in mine ( White Dash ) !! i have the RCD510 and it works a treat will the iphone 4, Samsung and nokia phone we have :yes: took about 2 to fit .
Just needs coding with vcd after fitted so that it works with the MFD and wheel controls ( Big thanks to shaun for doing mine )
NastyNick83
Re: Which Bluetooth
9W7 7P6035730C
or
5N0035730D
Thanks Nick
Surely coding is only required if you don't have the factory fitted bluetooth installed before fitting the replacement module?!
NastyNick83
Re: Which Bluetooth
ayeaye wrote:Either can be used with RCD510 and RNS510 - the 5N0 unit is a newer unit and would be the one I would go for if I was replacing a rSAP unit.
Thank you - just the answer I was looking for!
Shaun
Re: Which Bluetooth
Post by Shaun »
9W7 7P6035730C
or
5N0035730D
Thanks Nick
As you would be removing the old unit with the coding on it the new unit usually needs coding, some work out of the box too, but when VAG com'd they can show errors.
johnjm
Options: SatNav (retro), PDC, Votex kit, R-line rear bumper, s/r
Re: Which Bluetooth
Post by johnjm »
You need the 5N0035730D which supports both rSap and normal BT profiles (iphone). Great module.
1 6 D
Options: RCD510 with 8 speakers
Climatronic
Cruise Control
tinted rear windows
aerial in rear window
MFA Plus
Multi function steering wheel
Self-added:
Cornering fog lights
Coming Home
Leaving Home
4 stop bulbs at rear
Folding mirrors+ambiente lights+memory
Re: Which Bluetooth
Post by 1 6 D »
My dealer recommended me to add a Basic version, not Premium because it can work with most phones.
Is there a module for red cluster which can work with rSap and with normal BT profile like this 5N0035730D?
johnjm
Re: Which Bluetooth
Post by johnjm »
1 6 D wrote:My dealer recommended me to add a Basic version, not Premium because it can work with most phones.
There is, but its damn old and not worth it. I bought the 5N0 035 730A for my red MFD but I did so cos my phone supports rsap.
NastyNick83
Re: Which Bluetooth
I bought the 5N0 Bluetooth module and all seems to work fine with my iPhone. Great stuff.
However the quality is rubbish. I can hear them fine through the speakers but any speeds over 40mph and they can barely hear me. I've had reports of it sounding like I'm in a wind tunnel and riding a horse among others...
I've tried other phones including a windows mobile device and Nokia and none of them are any better... VW told me everything was fine (but they only tested it up to 30mph).
Any thoughts boys and girls?
johnjm
Re: Which Bluetooth
Post by johnjm »
Your wiring harness is at fault. Which one did you get?
