VCDS Coding - Auto-HVAC
ayeaye
Options: Candy White Scirocco - August 2009 - March 2013
Now replaced with a MINI Cooper S
Post by ayeaye »
Having retrofitted the MK6 climate control units, I'm wanting to make sure that the settings are correct. Have followed all the info on the various posts but having a CC in the driveway with the new unit, I compared the coding between the CC and the Scirocco - and there's a difference. On the CC, the option for "Air quality sensor installed" in unchecked (but is active as it's kicked in a few times) but there's no long coding helper description for byte 5 (or may be 4) that is set to 0000010, so I'm wanting to see if the Scirocco should be the same.
Could someone with VCDS and the post-week 45 2009 climate controls factory fitted provide the coding for Auto-HVAC so I can compare that against the CC, and also the part number of the unit installed (I've got 5K0 907 044 AK).
Any help appreciated.
Paul
