First Impressions , DAB, BT and USB
JG400
Options: Bluetooth, Mats, Digital Radio
Post by JG400 »
Just very 'first impressions' on the tech options I have in car,
Bluetooth , sync'd my HTC HD2 (which is running an Android rom) with no problems. Car detected the phone straight away and the whole process was very quick and smooth , tried it briefly to make a quick call using the contacts list and it worked fine , very impressed with the integration with both screens (MFD and main one) I think have briefly read that it can play media by Bluetooth but not checked it out and it might not even work with my phone.
USB, again I have connected my HTC via usb , had to modify the usb connection on the phone in order to access the SD card (which I should of realised!) but once I had done that all the albums appeared in the main display ,again the integration with the screen is excellen, not sure whats going to happen if someone rings I am hoping it cuts in and shuts the media down.
DAB, took some setting up as no stations were set , I am sure (hope) there is a better way to find stations than simply search for them but not found it yet , signal is great well impressed with it
