Drl,s
Simon_T
Options: DVD SATNAV
DYNA AUDIO 300 WATT SYSTEM UPGRADE
CRUISE CONTROL
BURY BLUETOOTH PREPARATION
ROOF MOUNTED BARS AND CYCLE CARRIER
FLOOR MATS
BOOT LINER
3 YEARS SERVICING
Drl,s
Post by Simon_T »
Hi i know this has probably been covered and ive done a search but cant seem to find the answer so can anyone help
day time running lights are on when the switch is 0 so can anyone tell me if the front and rear lights work in tandem and are the front lights just as bright as if you have your lights on anyway?
to me it doesnt seem any different. but when i switched to dipped only the side lights in the grill are on so im confused by this.
trix
Ordered 23rd June 09
Build week 41
Handover 17th Oct 09
Missing RW1
Re: Drl,s
Post by trix »
Simon
In simple terms as its late..
Drls = dipped beam on
Light switch settings (off the top of my head until I can check my car or a light switch picture)
0 = drls unless you have turned them off via whatever method (vagcom etc) in which no lights on at all
Second position = sidelights
Third position = dipped beams
It sounds like you are only turning the lights onto sidelights & not all the way to dipped beams
Simon_T
Options: DVD SATNAV
CRUISE CONTROL
FLOOR MATS
BOOT LINER
3 YEARS SERVICING
Re: Drl,s
Post by Simon_T »
thanks trix but what im seeing is when its set to 0 the lights are on anyhow front and rear or am i wrong?
seems i dont even have to switch them on to auto or anything
trix
Build week 41
Missing RW1
Re: Drl,s
Post by trix »
i knew i forgot a position on the switch :doh:
in auto with drls activated your lights will be on regardless as the drls effectively override the 'auto' function
& regarding the 0 position yes they will be on as the drl function is active, to have 0 as off & auto as automatic the drls must be switched off (in your case by vagcom due to your car being an MY2011) otherwise the drls override these functions
RW1
Legend
Hi from Sunny Stopfordia
Re: Drl,s
Post by RW1 »
Simon,
Front and rears on with DRL's in "0" and ignition ON. Nothing with ignition OFF.
Switch to AUTO, with ignition ON, DRLs are on still as the dipped headlights and also front sidelights/rears. Ignition OFF, no light at all front and rear.
Switch to Sidelights, with ignition on, outer dipped headlights ON (DRLs again) and front sidelights ON. Ignition off, front sidelights ON, rears ON in both cases.
Switch to headlights with ignition ON, DRLs are on still as the dipped headlights and also front sidelights/rears. Ignition OFF, front sidelights only.
Main Beam, inner headlights ON and the outer dipped stay ON (no main beam in this position). Obviously rears ON.
29 Oct'09 at dealers
Driving 4th Nov. Sorted!
