ESP Settings
- Malcolm
ESP Settings
Any got factory settings for various options of Sport/Normal/Comfort and then D/S in the DSG an effect it has on amount of slide the ECU allows?? I know for a fact the Bosch ECU in a 911 allows between 11-16% depending on whether Sport is selected and wondered if its a intuitive in a Scirocco and if Sport on the suspension and sport on DSg made a diff? It seems to change quicker, quciekr still with ESP turned off (although its never completely off).
http://www.chemtec.co.uk" onclick="window.open(this.href);return false;
Karcher-Center-Chemtec for all your Karcher Cleaning Equipment Needs!
0845-890 3600 #1
0845-890 3600 #1
- pat15312
Re: ESP Settings
:S good luck with that one mate?
even if you knew, how would you go about changing it?
222bhp & 340Nm
- Malcolm
Re: ESP Settings
Dont wish to change, obviously the suspension button is easy for adjustment just want to know what the underlying tech actually allows the vehicle to do......
0845-890 3600 #1
0845-890 3600 #1
