Hello all ---- 2017 2.0tsi
I've searched about and not seen this discussed yet..
I understand that there might be a place to tap for oil pressure on the head, but which is not one of the two oil pressure sensors (blue/brown) on the corner of the motor. Like, an oil galley with a little plug in it, which can be removed and an oil pressure sensor (or pipe) can be attached.
Any guidance? Is there a good/expected/usual place? OR is a T-fitting the only option?
What's the guidance for torque on the M10x1 fittings?
Thanks!
