I have retrofitted a MIB 2 PQ into my 2010 scirocco everythings work fine except the camera only working after a soft reset, if leave the car overnight the reversing camera wil not work I have to remotly soft reset the radio to get it to work.
I already have coded the reversing cam in the 5F longcodig and deactivated PDC adaptions in the 5F module, Could it be the aftermarket aliexpress backup cam? It does have a delay box for when you go from reverse to first that is stays on a little longer is it possible this delay box interferce with the original radio?
I am looking forward to some replies
Link to reverse cam https://nl.aliexpress.com/item/10050041 ... cification
