good afternoon chaps,
I bought my Rocco R Stage 2+ from a friend last year, which has had a few threads on this forum (https://www.sciroccocentral.co.uk/forum ... 13&t=23485).
I had in R-Tech couple weeks ago with a running issue which is now rectified (oil filler cap seal, MAF Sensor replaced) now i've had a print out of the vehicle record report and there's a few fault codes;
Wheel Dampening Electronics Code Scan
03262 Comfort Restriction - Intermittent (noticing a slight knock on O/S front when pulling off and going over the odd bump or pot hole)
00776 Level Control System Sensor Left Front (G78) Mechanical Malfunction - Intermittent (noticing the Xenon self levelling will occasionally act as if I've gone over a hill when going over a little bump in the road.
lastly the one that's really annoying is - Door Electronics Driver code scan 00131 outside door handle mirror light electrical problem in circuit.
anyone have any advice on rectifying these?
TIA
Advice on fault codes and how to rectify
bigkris06
Re: Advice on fault codes and how to rectify
I would say level sensor but as you have a knocking coming from somewhere I’d rectify that first as it may be giving false readings. Could be something as simple as a drop link or ball joint. Did you have any advisories on your last mot?
Do you have any issues with the door light or anything else electrical wise in the door as may be a wiring issue in the loom between the door and car.
