Cruise Control
4thscirocco
Options: Bought it pre-optioned. ;)
Cruise Control
Post by 4thscirocco »
Is there a common failure of the CC switch stalk? I used it once, and it hasn't worked since. No dash light when I try to enable the CC. :shrug:
1975 Mk1
1976.5 Mk1 Wolfsburg Edition
1982 Mk2
2009 Mk3
bigkris06
In: Pewter Grey
Re: Cruise Control
Post by bigkris06 »
Are you sure it has ever worked?
Some models didn’t come with cruise control as it was an optional extra.
Some people add just the stalk and hope it works but obviously it won’t.
I can’t remember the exact dates but from memory it was at some point in 2010 they changed the cruise control system so early models have just the cruise control on just the left hand stalk, newer models have the the whole stalk unit plus clock spring (stalk unit for both indicators and wipers) and there are only certain variants that work.
Then it needs to be coded.
If you are 100% sure it has worked may be worth checking if there is any codes as sometimes could be something as simple as a faulty brake light / clutch pedal switch.
Hope this helps 😊
4thscirocco
Re: Cruise Control
I'm sure it worked once, because I couldn't cancel the setting until i touched the brake pedal.
I was fixated on the switch, so I didn't look for codes. Something to try.
1975 Mk1
1982 Mk2
2009 Mk3
