Right mirror turn signal doesn't work
Vorocid
Post by Vorocid »
Hi. I recently discovered that turn signal doesn't work and I don't know why. I bought a new LED turn signal like the original but still not working with the new one.
Everything else is working on the that right door except the heating in the mirror also not working from last winter. Can these 2 faults be related, maybe some defect fuse or relay?
Scirocco 3 1.4 160Hp 2009
bigkris06
In: Pewter Grey
Re: Right mirror turn signal doesn't work
Post by bigkris06 »
Yes I’d definitely say they are related as the loom from the door goes out through the mirror. There is likely to be a wiring or connector issue.
Does your electric mirror work? (Adjusting the angle / view etc)
