Hi guys, how easy is it to change out the blower motor on a 2016 1.4 TSI? My blower isn't working on any setting and can't see anything obvious with the fuses although goin on some diagrams there is a 40amp fuse missing, should there be 2 40 amp fuses? Going on the videos I've seen it looks fairly simple to change but unsure if the videos are accurate, does the motor really just clip off then rotate out from under the glove box? It's a RH drive.
Thanks.
