Shortly after, the right headlight stopped working, the left rear blinker stopped working, and right rear light stopped working, all in 1 go..
I checked all the fuses first, but they were all fine, then I took out all the bulbs out of the car and manually checked them, they're all working fine too..
Then I replaced my front blinkers/drl since that seemed to be where it started, but made no difference, same symptoms
So since my battery was sitting at 11.7v even after wallcharging it all night, so I decided to replace that (was long overdue anyway), but after having just installed a new battery, didn't make any difference either..
I tried to wipe all the error codes via obd2, didn't help, and then I tried to reset the whole thing by doing the whole thing by (with the driver door open) disconnecting the battery for 15 seconds connecting the positive and negative together for 10 seconds to discharge the capacitor and then leave the car on ignition for 30 sec, but didn't work either
I have measured the wiring of the lights that stopped working, and the wires themselves are no longer getting power, as if they've been cut off
Also only the outer lights are affected, everything else is working perfectly fine, indoor bulbs, seatheating, power steering, radio, etc
Anybody got any ideas for me? I've genuinely run out of things to check..
Edit: Apparently sciroccos have 2 fuse boxes, who knew.. (I didn't), found a blown fuse in the engine bay fusebox, I hope that'll turn out to be the crux...
