Hi guys i had my front drivers side wheel bearing replaced today and although it sounds better ,when I'm doing 70mph plus there is still a sort of rubbing noise coming from the front
Any ideas please
Humming noise
Re: Humming noise
Have you checked the tyre?
You could try swapping the wheels around to check.
You can get a humming / rumbling noise, similar to a worn bearing, at certain speeds due to tread stepping and sawtooth wear on the tyres. The scirocco is prone to this but it's normally the rear tyres that suffer.
