Engine 1.4 TSI 160 hp, with 46.500 Km's.
What else can I check to end misfires...
The engine has no compression problems (it has been tested several times), NGK IX spark plugs (BR8EIX) have been placed, best ignition coils on the market have been installed (IP - Ignition Projects).
The problem is that misfires continue to appear, example: if the car stays on the garage one day without working, the next day it gives misfire. If it runs every day, nothing happens.
Someone told me it should be injectors or the low pressure gas pump...
What do you think?
Thanks in advance
