Not enough power at low RPM
Samvdf
I drive a: 1.4 TSI 122/125
Post by Samvdf »
Hello guys,
I'm having some trouble with my scirocco 1.4 tsi 122 hp.
The car has power loss from 0-3000 rpm. It accelerates much slower than it should. At 3000 rpm or higher, the car gets its full boost and power.
It feels like it's accelerating on the motor and at 3000 rpm, the turbo kicks in.
There are no engine lights or fault codes.
I replaced the turbo and everything that's attached to the turbo (boost solenoid, valve, wastegate...) so that can't be the problem.
I did some tests with the computer and the boost pressure is perfect, camshaft adjustment also working perfectly.
I also checked the intake pipes with a camera and it seems like there is no pollution in it.
Has anyone had the same experiences?
Tips on what to check next?
Thanks!
Sam
Mike_k5
Re: Not enough power at low RPM
Post by Mike_k5 »
Hey guys, I’m waking up an old thread here but just like the O.P my 2.0 tsi seems quite sluggish at low rpm and it’s not until I hit around 3000rpm when you really feel it pull harder as the turbo kicks in.
I’ve not had the car long, I have No warning lights or fault codes.
Im assuming this low rpm sluggish feeling isn’t right?
Any input would be appreciated :-)
LukeDavies
Options: Sunroof
Cruise control
Heated leather seats
Post by LukeDavies »
Hi Mike. My 2009 2.0 TSI was the same. Turbo would only kick in after like 3k plus RPM. However I knew what the problem was. I had the ever dreaded turbo wastegate rattle. And mine was very loose so that’s why my lower revs were underpowered. Sent my turbo off for a refurb and now my car has life again. Kicks in about 1.8k which I believe is spot on. Nice surge of air noise as well if I have my windows open, which I never had before lmao!
