Engine cover removal
taylermullettvw
Options: NOTHING
Post by taylermullettvw »
This maybe really simple to someone who knows what they're doing lol. However, trying to remove the engine cover on a 2016 Scirocco R is proving impossible without feeling like I'm going to snap something. Could anyone help?
Thank you :D
Bandwagon
Re: Engine cover removal
Post by Bandwagon »
My cars an older spec but I pull from each corner of the cover u might be able to find the clamps with your hand under the four corners. It is scary to pull off Still. If your still nervous YouTube is the job
Phil
In: Night Blue
Post by Phil »
Bandwagon wrote:My cars an older spec but I pull from each corner of the cover u might be able to find the clamps with your hand under the four corners. It is scary to pull off Still. If your still nervous YouTube is the job
I believe you have a different cover. The R is bit trickier - not that I have ever taken on the challenge
Phil
kentech
Post by kentech »
Basically the same as in this video.
[youtube]cfaUCHyXZew&[/youtube]
Babajang
In: Indium Grey
Post by Babajang »
you have to detach the air intake, some piping clips and cables from the cover...
Then you have to really pull hard on the areas that the cover connects to the engine on.. i broke one of the mounting points, luckily cheap to replace... but yeah its overly tight... i had to take it off a second time and it was just as tight that time as well. Good luck.
3t3p
Options: R-tech Stage 1, Forge Twin take,19'' Talladegas, Rear sensors, Heated leather, RNS510 Satnav + Dynaudio, Tinted glass, LED Interior lighting, Electric folding mirrors, Custom mats, CBI Xenons, Yellowstuff pads
Post by 3t3p »
run the engine 5-6 mins to warm it up slightly too.
Have to be brutal maybe put work gloves on for protection and to be able to apply more force
