Bit of a weird one, noticed the other day when changing the clock back an hour that the "Convenience" option in my MFD settings has changed to "Komfort".
Checked language settings and they're on English, all other menus are as normal, and funnily enough when you click into the komfort menu it shows the header at the top as convenience, see photos:
Does anyone know what may have caused this? It did go in for a service and the ABS recall last month, that's the only thing I can think of recently that may have caused it. Prior to that, the last time I fiddled in VCDS was back in May/June time so there is a slight possibility I ticked something I shouldn't have, though I would've thought I'd have noticed before now as I'm always fiddling in the MFD.
MFD "Convenience" setting changed to "Komfort"
- charliegilmanuk
