Creaking doors
- In: Pure White
Creaking doors
Anyone had a problem with creaking doors when closed and moving had car jacked up because of puncture a couple of weeks ago since then drivers door creaks when on the move got it in at dealer in 2weeks anyone else had issues like this it's getting on my nerves
- In: Pure White
Re: Creaking doors
Just in case anyone has this problem had a look and found the door latches completely dry of grease and rattle so filled them with grease and think I've solved my creaking car only 16mths old think vw a bit tight when it comes to grease or I'm to keen on washing around the doors.
- Adam90
Re: Creaking doors
Try using Gummi Pflege. It worked with mine, temporarily, but I have to re-do it every few months.
Re: Creaking doors
On mine the creaking comes from the window seals and as said above gummi pfledge helps a lot.
