Engine Start/Stop Issue
- In: Shadow Blue
So I've been having this issue whenever I'm In traffic or at a light and my engine goes off because of the start/stop function. But the problem is during the start phase where the engine sometimes doesnt start back up when I'm about to pull away, it tries once or twice and sometimes doesn't start up and I have to manually turn the ignition off and restart the car.
What I do now is turn the start/stop function off to avoid this problem. But I need a permanent fix.
I have a 2014 2.0 TDi blue motion DSG if that helps.
Anyone else having a similar issue and know what the solution for this issue is?
Re: Engine Start/Stop Issue
If it's 2014 it's still under warranty, I'd have it back into VW and get them to sort it for free.
I was about to say the same thing, let VW have a look at it rather than ask a bunch of strangers on a forum, lolPaddy_R wrote:If it's 2014 it's still under warranty, I'd have it back into VW and get them to sort it for free.
- SPEEDDRV
Sometimes those "bunch of strangers on a forum" are more helpful than a "bunch of strangers at VW Dealership".rpsmith79 wrote:I was about to say the same thing, let VW have a look at it rather than ask a bunch of strangers on a forum, lolPaddy_R wrote:If it's 2014 it's still under warranty, I'd have it back into VW and get them to sort it for free.
- In: Shadow Blue
I have mechanical breakdown cover and also the warranty on the car, I was going to take it in but I thought all of you guys would love to weigh in lol
And if it was a simple fix why send it to VW lol
This post says you may be able to code out stop / start with VCDS http://www.sciroccocentral.co.uk/forum/ ... 36&t=23500" onclick="window.open(this.href);return false;
- T33beh
I have the same issue and it's due to the flywheel 'deteriorated' according my the AA. [emoji19]
- Roy_01
Im not sure it will work but i have that option in vcds.chelspeed wrote:This post says you may be able to code out stop / start with VCDS http://www.sciroccocentral.co.uk/forum/ ... 36&t=23500" onclick="window.open(this.href);return false;
But can't try it out because i don't have start stop.
- Roy_01
Anyone tried it yet?
The method I heard about was to set the voltage at which start/stop works via VCDS to above 14v. If the battery voltage is below the set voltage then the start/stop will not operate. Not tried it yet as I do not have access to VCDS that will work with a 2016 car.
