RCD510 / 7P6 Bluetooth help.
Actually, I had installed 7P6 N module on my RCD510 (Bosch). However, it can't show any track name and forward/reverse control for BT-audio. is it I miss some setting about that? or it caused by my RCD510? Anyone can help me to solve this issue??
Re: RCD510 / 7P6 Bluetooth help.
anyone help
Is it caused by RCD510??
It may be the module is not the correct match for the RCD510. This link may help:
http://www.scirocconet.co.uk/forum/blue ... 11456.html" onclick="window.open(this.href);return false;
I thought the module you need is the 9w7 type...
Most scirocco's are all the same but some are different...
Possibly an old RCD510 unit. Whats the part number?
- Phil
- In: Night Blue
I had this on my old gt on the orginal rcd. Decided to upgrade to the rns (for the nav not the missing track info) and was suprised to see it had solved that issue too!
Phil
Where is the part number? on the label of RCD510??dimexi wrote:Possibly an old RCD510 unit. Whats the part number?
I checked the coding which don't show fault code of this module.salsajoe wrote:It may be the module is not the correct match for the RCD510. This link may help:
anyone help?
- Phil
- In: Night Blue
As said, I had this when I installed Bluetooth on my old GT with the RCD510. It changed when I upgraded to the RNS, leading me to believe that older versions of RCDs are not capable of showing this. Might be worth having a search for a newer RCD, should be a straight swap (remember to get your radio code from VW first if you haven't already) but I can't confirm this would solve the issue.
Phil
if I buy a new RCD510 for this issue, which code or part number of RCD510 I need?
(ps: I also installed the packing camera)
