ipod issues...
ipod issues...
Anyone on here got there ipod working? Mine is charging through thr USB but the 'media in' doesn't want to recognise it.
Help me!!!
Help me!!!
It's here!!! rising blue, sunroof, cruise, ejector seat, dab, lumbar, leather.
- rehmondo
Re: ipod issues...
I think you need to use the VW ipod cable for it to work, are you using that or are you using your ipod usb cable and plugging it into the USB Media Cable?
- CTRnutter
Re: ipod issues...
also you need to go into the setup and enable the media ports
Car is now Sold!!!!! BMW 7 Series for now as nice and big but holding out for something a little special as my toy
Re: ipod issues...
I just changed the cables over and it work? Didn't have to change anything else!CTRnutter wrote:also you need to go into the setup and enable the media ports
- CTRnutter
Re: ipod issues...
I had to enable the media ports, as you can switch them on and off, also not sure if you guys are aware but western digital do some rather nice portable hard drives called passports, I have a 120GB one, and you just load that up with music seperating artists in folders and albums under that and it works exactly the same as the Ipod using the USB lead. Seeing as you cant use the Ipod video features, or use the album artwork, I am currently setting my passport up with everything music wise only got 80gb worth of music so far!! it also seems to be quicker than the ipod for browsing etcHantsMan wrote:I just changed the cables over and it work? Didn't have to change anything else!CTRnutter wrote:also you need to go into the setup and enable the media ports
- rehmondo
Re: ipod issues...
Cool, thanks for that, wouldn't have thought about trying it, just didn't think it would power the device, I know it worked fine with my 4GB USB stick.
Do you off hand whether it supports NTFS formatted HDD or will it have to be in FAT32 for it to recognise?
- CTRnutter
Re: ipod issues...
Mine was formated to fat 32, also I you can adjust the power the USB lead supplies in the options you need to put that to fullrehmondo wrote:Cool, thanks for that, wouldn't have thought about trying it, just didn't think it would power the device, I know it worked fine with my 4GB USB stick.
Defo worth it
- rehmondo
Re: ipod issues...
OK so I got my spare WD Passport (250GB) it already has my music collection on it as I have it connected to my PS3 and for that to see it, it had to be FAT32.CTRnutter wrote:Mine was formated to fat 32, also I you can adjust the power the USB lead supplies in the options you need to put that to full
Defo worth it
I plugged it in the USB cable in the car, the light came on and it powered the HDD, usually when there isn't enough power you can hear the disk spinning, starting, starting starting etc In the car I don't have that issue, but nothing shows up on the screen.
Would you mind telling me where the power setting is for that? Is that the 1.7V option in AUX? I changed that to the other two and still nothing? The drive makes a noise as if its being accessed but again nothing appears on the screen.
It would be amazing to get this working as I was hoping to make use of my old 40GB iPod, but that didn't work with the iPod cable, I know the cable and port works in my car as my iPhone works perfectly with it, charges and the few songs on it appear on the screen.
Would really appreciate your help with this.
- CTRnutter
Re: ipod issues...
I'll pop out there and write it out for you in stepsrehmondo wrote:OK so I got my spare WD Passport (250GB) it already has my music collection on it as I have it connected to my PS3 and for that to see it, it had to be FAT32.CTRnutter wrote:Mine was formated to fat 32, also I you can adjust the power the USB lead supplies in the options you need to put that to full
Defo worth it
- rehmondo
Re: ipod issues...
Thanks manCTRnutter wrote:I'll pop out there and write it out for you in steps
*Edit - I got it working mate, I moved the music closer to the top level and it worked plus I had some exe files at the top level, after removing those it fixed the issue and now the HDD can be used as music storage, glad I don't need to buy another iPod now
Would never have thought my WD would work, thanks again!
- Kev
- Administrator
Re: ipod issues...
Might be worth adding some of that info to the wiki page for the ipod connectivity if you get the chance.
Re: ipod issues...
i pod set up was so easy and love the artist names etc on the views
- jonosussex
Re: ipod issues...
Anyone have problems getting an iPod nano to work? My mini works fine - but the Nanos (8G) is really tempremental.
Mind you seems to me there's a lot of hard disc space looking to be used
Also... I didn't get a USB lead with my Roccy - are they standard? I figured I could load the HDD with MP3s via a big USB memory stick...
1996-1999 Mazda 323 2.0 V6
1999-2002 Celica 190
2002-2005 Celica T-sport
2005-2008 Golf GTi
2008-2011 'Roc 2.0 TSi manual - Rising Blue
2011- ?? Roc 2.0 TSi DSG Indium Grey
2005-2008 Golf GTi
