19" Lugano tyre pressures
RJM85
Options: 19inch Lugano's, Winter Pack, Protection Pack, Rear Parking Sensors, Bluetooth, Cruise Control, Philips Xtreme Vision Bulbs
Post by RJM85 »
Does anyone know the factory pressures for the tyres on the 19" Lugano alloys with 235/35/r19 tyres? Ive looked in the handbook and I can't see the info?
Cheers!
Shaun
Re: 19" Lugano tyre pressures
Post by Shaun »
The manual tells you to look behind the fuel filler flap, do you have the sticker there ?, anyway its 38 Psi for a normal load according to my sticker.
As above, tells you inside the fuel flap although I'm sure mine says 36psi
Shaun
Post by Shaun »
Its dependent on model and spec etc i believe as some are heavier than others.
Shaun wrote:Its dependent on model and spec etc i believe as some are heavier than others.
Good point, his is a diesel the same as mine so should be the same
RW1
Legend
Hi from Sunny Stopfordia
Post by RW1 »
I'd expect the 170ps Diesel at front axle loading of 1080kg to be 38psi???
140PS diesel @ 1050Kg 33psi
170PS diesel @ 1080Kg 35psi.
1.4(160PS) @ 1010Kg 33psi.
2.0TSi @ 1040Kg is 36psi.
2.0 R a@ 1070Kg 38psi
All rear axles on models are 770kg yet the pressure goes up ?????
I'm not going into the maths again as I've just done tyres pressures calculations on a new vehicle at work just before Christmas.
29 Oct'09 at dealers
Driving 4th Nov. Sorted!
Ryy
Options: Sat Nav, Heated Leather Seats, Dynaudio, Kit with 19" alloys, 30mm Front / 20mm Rear Lowering Springs, Folding Mirrors, Interior Mats, REVO Stage 1, Carbon wrapped bits and bobs.
Post by Ryy »
Mine definitely says 36psi for normal (not fully brimmed with people and luggage)
RJM85
Post by RJM85 »
Thanks for the info! I'll check out the filler cap tonight and confirm what mine says. :)
Komar
I drive a: 1.4 TSI 122/125
Post by Komar »
Mine says 30.4 or 30.9 psi....not sure
its 205/50R17
RJM85
Post by RJM85 »
Heres a pic of the chart behind the fuel filler cap! I checked my pressures today for the first time, and every tyre was 24 psi! Not impressed!
lugano
Tyre Pressure
Post by lugano »
Can anyone out there clear things up for me as to what is the correct tyre pressure for my car with the 19" lugano's. The fuel cap indicator suggests 42 psi but it also shows images of a full load :? . Normally i drive the car by myself & occasionally i'll have friends in the car at the weekends.
Re: Tyre Pressure
Fuel cap gives a range, accorging to my flap it's 35 all round for normal and 38F and 42R for fully loaded for all standard 4 tyre options .
lugano
Re: Tyre Pressure
Post by lugano »
Looking at my fuel cap it only gives the 42 psi advice, it also gives lesser tyre pressure's but they relate to smaller dia wheels (18"/17" etc)
Re: Tyre Pressure
lugano wrote:Looking at my fuel cap it only gives the 42 psi advice, it also gives lesser tyre pressure's but they relate to smaller dia wheels (18"/17" etc)
You're not reading the sticker correctly.
The 4 tyres sizes are all in one box so the half load and full load refers to all the sizes
lugano
Post by lugano »
Its ok i'll go by the earlier thread & stick to the answers in that one, thanks all
lugano
Post by lugano »
Thanks Cupracob maybe wasnt reading the tyre sticker correctly but its not laid out in the most logical manner & it confused me.
lugano wrote:Its ok i'll go by the earlier thread & stick to the answers in that one, thanks all
If you look at the picture a few posts back from the sticker you can see it's quite clear. 4 sizes, 2 loads and corresponding pressures. Below these are the 2 winter tyre sizes on both loads and corresponding pressures.
Just go with what your flap says.
lugano
Post by lugano »
Sorry to bring this up again, i've checked the fuel cap & on mine the tyre pressure is 33psi fronts & 33 psi rears for 2 persons + suitcase, hope this is correct as it seems a bit low even though that is what's stated on the fuel cap. I thought that because mine are 19" then the bottom row was applicable to me.
RW1
Legend
Post by RW1 »
The 1st left column are all the tyres v the half & full settings when reading the tank flap label.
Although there are minor differences psi/fractions of a bar, here is the table for all (Official)
Engine Power Rating conversion table
Kw --- PS ------ Model
........ TSi ........
90 .... 122 ..... 1.4TSi
118 ... 160 ..... 1.4TSi
147 ... 200 ..... 2.0TSi
155 ... 210 ..... 2.0TSi
188 ... 256 ..... 2.0 R (Australia)
195 ... 265 ..... 2.0 R
........ TDi .........
103 .... 140 .... 2.0TDi
125 .... 170 .... 2.0TDi
Tyre Pressure Table - All Scirocco Models
So tends to agree for TDi's that all wheel sizes have the same tyre pressures no matter wheel & tyre fitment.
Tyre pressure gauges ain't that accurate so any differences of 1 or 2 psi are not worth fiddling over. Check the wear rate and wear pattern trends over time and adjust using solely one tyre pressure gauge.
lugano wrote:Sorry to bring this up again, i've checked the fuel cap & on mine the tyre pressure is 33psi fronts & 33 psi rears for 2 persons + suitcase, hope this is correct as it seems a bit low even though that is what's stated on the fuel cap. I thought that because mine are 19" then the bottom row was applicable to me.
That's the way I read your sticker too, 33psi all round.
I can understand why you would think the higher pressures would apply as the 19" is the bottom line but I can assure you that is not the case. The pressure apply to all the 4 sizes of tyre.
