OllieMK
- I drive a: R-Line
Hard wired my dashcam. Works a treat. Hiding the wires took a bit of work though.
Sent from my SM-G925F using Tapatalk
dimexi
Hiding the wires in the roof trim takes a day and an AGE!!!!OllieMK wrote:Hard wired my dashcam. Works a treat. Hiding the wires took a bit of work though.
OllieMK
- I drive a: R-Line
Got there in the end. Looks much neater than having it plugged into the 12v socket.dimexi wrote:Hiding the wires in the roof trim takes a day and an AGE!!!!OllieMK wrote:Hard wired my dashcam. Works a treat. Hiding the wires took a bit of work though.
tyrannosauRoss
I need to get around doing that!OllieMK wrote:Got there in the end. Looks much neater than having it plugged into the 12v socket.dimexi wrote:Hiding the wires in the roof trim takes a day and an AGE!!!!OllieMK wrote:Hard wired my dashcam. Works a treat. Hiding the wires took a bit of work though.
TheHungryHipo
Installed my Forge twintake, cars sounds like Darth Vader breathing now!
- Ibifaho
Lowered the rocco with coilovers and put Skoda Yeti exhaust tips on.
Mugshot
First bag of Sand!
- C00PS
Had to sort this mess out today. Not what I needed. Lucky enough it's payday today [SMILING FACE WITH SMILING EYES]
Greatbatch13
A roof landed on my rocco i got two days ago.......scratched to death.......i cried. But at least it will be fixed and look better than ever scratch free!!
Wooo
Wooo
- easyrider
bought my second new tyre this week which is my sixth in 3 months. not happy about losing £800 on rubber [emoji35]
- Psycho Kirky
Pirelli P Zero's just fitted, now having an MOT!
Watch out when ordering tyres online. Tyres are all good, just 2 have Mercedes compound and 2 have Audi compound.
Shouldnt be any difference really but may have slight difference in wear patterns for them certain cars.
Try and order all 4 at once unlike me 2 and 2.
Sent Via tapatalk
Sent Via tapatalk
dimexi
Had my two fronts changed. Pirelli p zeros as usual.
Need to change my airbag controller (again) this weekend sometime.
Also need to sort my EML/intake manifold issues before its service on Friday
dimexi
So after the saga of getting a broken airbag controller off eBay (my fault, the fact it was £40 should have been telling), finally got another for 99£ and fitted it today. I have now taken my steering wheel off 4 times in just over a year! I think I can do the cruise control retrofit with my eyes closed.
New fronts fitted Goodyear Eagle F1 Asymmetric 2,s same as backs... Tracking was shot to pieces so had that sorted too (fecking pot holes) .... More new led bulbs for my plates.. Thinking about ordering my inside LEDs to fit next weekend
- Phil
- In: Night Blue
Can I take you up on that [WHITE SMILING FACE]dimexi wrote:So after the saga of getting a broken airbag controller off eBay (my fault, the fact it was £40 should have been telling), finally got another for 99£ and fitted it today. I have now taken my steering wheel off 4 times in just over a year! I think I can do the cruise control retrofit with my eyes closed.
Phil
dimexi
Yeah, I dont mind Phil!
You'd have a long trip to make though? Except I bring my tools when I visit friends/family back in london on one of my weekends.
You are around the M25 arent you?
greg7728
any guide on how to take steering wheel off/ do u have to replace any parts of u do? Got a scratchy noise behind it when turning the wheel, sounds like grating on plastic, suspect something broken behind there.dimexi wrote:So after the saga of getting a broken airbag controller off eBay (my fault, the fact it was £40 should have been telling), finally got another for 99£ and fitted it today. I have now taken my steering wheel off 4 times in just over a year! I think I can do the cruise control retrofit with my eyes closed.
dimexi
UKLee wrote this guide on cruise control retrofitting. It's a brilliant guide and has instructions on taking off the steering wheel. It's the hardest bit.
The grating plastic you hear is probably your cowls not sitting properly. If you look at my upper cowl in that picture (my upper cowl isnt actually shown in that... I could upload a pic if you want), you'll see some wear marks on the top... I had that for a year! My upper cowl broke and I replaced it, but I had to replace the lower too and forgot. I've done it now.
the guide will have all you need
Edit: You dont need to replace any parts when you do, except the cowl if damaged. VW recommend you change the steering wheel bolt, but as Lee's guide says, you can clean it and reapply some thread locker.
dimexi
Clean bill of health now, all problems sorted, now ready for Friday's service
Code: Select all
VIN: WVW* Mileage: 84340km-52406miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
77-Telephone -- Status: OK 0000- easyrider
nothing better than a clean scan, dimexi! nice
